Lisp routine for coordinate dimensions
Message 1 of 10
Does anyone have a lisp routine that will globally dimension a series of coordinates similar to how they are shown in the enclosed attachment ?
thanks
Mark
Replies (9)
Message 2 of 10
Ranjit_Singh
A quick example
(defun c:somefunc  (/ pt)
 (while (setq pt (getpoint "\nSelect Ordinate point:"))
  (command "._dimordinate" pt (mapcar '- pt '(2 0 0)) "._dimordinate" pt (mapcar '- pt '(0 2 0)))))
Message 3 of 10
braudpat
Hello Ranjit
Your routine is so beautiful, so compact, so AutoLisp !
Thanks, Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 10
HI Ranjit, great lisp file, but when I try to pick a point using an osnap such as intersection, it only gives me one coordinate. When I pick a floating area as per your screen shot it will give me both X & Y
Message 5 of 10
Ranjit_Singh
braudpat wrote:
Hello Ranjit
 Thanks @braudpat
Can you provide some demonstration or more details. I am not able to replicate the problem. It works even with osnap for me.
Message 6 of 10
ВeekeeCZ
Isn't it just the osnap issue?
  (command "._dimordinate" "_non" pt  "_non" (mapcar '- pt '(2 0 0))
           "._dimordinate" "_non" pt "_non" (mapcar '- pt '(0 2 0)))))
Message 7 of 10
Ranjit_Singh
I honestly don't think so. Seems like OP wants to use osnap, and when he does he just gets one of the ordinate dimensions. That doesn't make sense to me.
Message 8 of 10
HI,
so I tried reloading the lisp file and now it does work with Osnaps. No sure why it didn't the first time. One other question and then I'm set. If I want the X coordinate to show on the right instead of left, is that adjusted in the dimension settings ?
thanks
Message 9 of 10
Ranjit_Singh
Yes, something like this to flip the x-corodinate
  (command "._dimordinate" pt (mapcar '+ pt '(2 0 0)) "._dimordinate" pt (mapcar '- pt '(0 2 0)))));+- option
and this to flip y
  (command "._dimordinate" pt (mapcar '- pt '(2 0 0)) "._dimordinate" pt (mapcar '+ pt '(0 2 0)))));-+ operation
Really there could be four different combinations; ++ (NE Quadrant) +-(NW Quadrant) -+(SE Quadrant) -- (SW Quadrant)
Message 10 of 10
PERFECT !!!
Thanks again for your help
