- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've been using the lisp below with succes on my old PC, but somehow it doesn't react the same way on my new PC.
(defun c:BAB (/) (c:BrstAllBlocks)) (defun c:BrstAllBlocks (/ sstBlocks) (setvar "cmdecho" 0) ;;; START REMOVE BLOCKS (setq sstBlocks (ssget "X" '((0 . "INSERT")))) (if (= sstBlocks nil) (princ "\nNo blocks present in this drawing")) (while (and (/= sstBlocks nil) (> (sslength sstBlocks) 0)) (princ (strcat "\nNumber of blocks to burst: " (itoa (sslength sstBlocks)))) (sssetfirst nil sstBlocks) (c:burst) (setq sstBlocks nil) (setq sstBlocks (ssget "X" '((0 . "INSERT")))) ) ;;; END REMOVE BLOCKS (Defun C:ByToCol() (vl-vbarun "P:\\DATA\\ACAD\\Common Files\\Lisp\\by2col.dvb!Module1.ColorToEntity") ) (setvar "cmdecho" 1) (princ) )
After the burst command it now asks me to select the objects to burst for the second time, as you can see in the log below: Command: bab Number of blocks to burst: 2 Initializing...0 found Select objects: I've exported the profile of the old computer and imported it on the new one to be sure every setting is the same. I even copied the old shortcut to the new computer to be sure Autocad Mechanical is started with the same profile. Although it worked on my old computer somehow, I think my lisp routine is messy and some lines are not necessary or clean enough. Can anyone tell me what's going wrong, espescially in this part:
Thank you in advance.
