LISP Routine - Change Block Base Point to Middle of Block
emreakyazici
emreakyazici
Hello everyone, couple days ago, I posted a question about Change Block Base Point and 2 LISPs that have created before are posted. Right now, I have to deal with DWGs from other companies and drawers, i need to apply blockreplace of their blocks but sometimes there are thousands of blocks are need to be replaced.
In Lee-Mac's LISP, we select the block and select the pickpoint, after then, position of remains same and base point is changed. Appyling with this method is helpful, however, still in big DWGs, sometimes it takes days to apply one by one.
I thought the best method is detecting xmin, xmax, ymin, ymax among the all components in block and move the base point to XF((xmin+xmax)/2, (ymin+ymax)/2), automatically (just like in figure 1).
For appyling, if selecting multiple blocks and appyling automatically instead of one by one is possible, it would be literally amazing. Thanks for your attention. I'll put 2 DWGs in order to be an example, I hope application might be suitable for use for multiple blocks and not one by one.
d1.1.dwg is before application and d1.2.dwg is after.
Here is Lee-Mac's LISP:
;;--------------------=={ Change Block Base Point }==-------------------;;
;;  This program allows the user to change the base point for all       ;;
;;  block references of a block definition in a drawing.                ;;
;;  The program offers two commands:                                    ;;
;;  CBP (Change Base Point)                                             ;;
;;  This command will retain the insertion point coordinates for all    ;;
;;  references of the selected block. Hence visually, the block         ;;
;;  components will be moved around the insertion point when the        ;;
;;  base point is changed.                                              ;;
;;  CBPR (Change Base Point Retain Reference Position)                  ;;
;;  This command will retain the position of the each block reference   ;;
;;  of the selected block. Hence, each block reference will be moved    ;;
;;  to retain the visual position when the base point is changed.       ;;
;;  Upon issuing a command syntax at the AutoCAD command-line, the      ;;
;;  program will prompt the user to select a block for which to change  ;;
;;  the base point.                                                     ;;
;;  Following a valid selection, the user is then prompted to specify   ;;
;;  a new base point relative to the selected block.                    ;;
;;  The block definition (and block reference depending on the command  ;;
;;  used) will then be modified to reflect the new block base point.    ;;
;;  If the selected block is attributed, an ATTSYNC operation will      ;;
;;  also be performed to ensure all attributes are in the correct       ;;
;;  positions relative to the new base point.                           ;;
;;  Finally, the active viewport is regenerated to reflect the changes  ;;
;;  throughout all references of the block.                             ;;
;;  The program will furthermore perform successfully with rotated &    ;;
;;  scaled block references, constructed in any UCS plane.              ;;
;;  Please Note:                                                        ;;
;;  A REGEN is required if the UNDO command is used to undo the         ;;
;;  operations performed by this program.                               ;;
;;  Author:  Lee Mac, Copyright © 2013  -  www.lee-mac.com              ;;
;;  Version 1.5    -    20-10-2013                                      ;;
;; Retains Insertion Point Coordinates
(defun c:cbp  nil (LM:changeblockbasepoint nil))
;; Retains Block Reference Position
(defun c:cbpr nil (LM:changeblockbasepoint t))
(defun LM:changeblockbasepoint ( flg / *error* bln cmd ent lck mat nbp vec )
    (defun *error* ( msg )
        (foreach lay lck (vla-put-lock lay :vlax-true))
        (if (= 'int (type cmd)) (setvar 'cmdecho cmd))
        (LM:endundo (LM:acdoc))
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
            (princ (strcat "\nError: " msg))
        (princ)
    (while
        (progn (setvar 'errno 0) (setq ent (car (entsel "\nSelect Block: ")))
            (cond
                (   (= 7 (getvar 'errno))
                    (princ "\nMissed, try again.")
                (   (= 'ename (type ent))
                    (if (/= "INSERT" (cdr (assoc 0 (entget ent))))
                        (princ "\nSelected object is not a block.")
    (if (and (= 'ename (type ent)) (setq nbp (getpoint "\nSpecify New Base Point: ")))
        (progn
            (setq mat (car (revrefgeom ent))
                  vec (mxv mat (mapcar '- (trans nbp 1 0) (trans (cdr (assoc 10 (entget ent))) ent 0)))
                  bln (LM:blockname (vlax-ename->vla-object ent))
            (LM:startundo (LM:acdoc))
            (vlax-for lay (vla-get-layers (LM:acdoc))
                (if (= :vlax-true (vla-get-lock lay))
                    (progn
                        (vla-put-lock lay :vlax-false)
                        (setq lck (cons lay lck))
            (vlax-for obj (vla-item (vla-get-blocks (LM:acdoc)) bln)
                 (vlax-invoke obj 'move vec '(0.0 0.0 0.0))
            (if flg
                (vlax-for blk (vla-get-blocks (LM:acdoc))
                    (if (= :vlax-false (vla-get-isxref blk))
                        (vlax-for obj blk
                            (if
                                (and
                                    (= "AcDbBlockReference" (vla-get-objectname obj))
                                    (= bln (LM:blockname obj))
                                    (vlax-write-enabled-p obj)
                                (vlax-invoke obj 'move '(0.0 0.0 0.0) (mxv (car (refgeom (vlax-vla-object->ename obj))) vec))
            (if (= 1 (cdr (assoc 66 (entget ent))))
                (progn
                    (setq cmd (getvar 'cmdecho))
                    (setvar 'cmdecho 0)
                    (vl-cmdf "_.attsync" "_N" bln)
            (vla-regen  (LM:acdoc) acallviewports)
    (princ)
;; RefGeom (gile)
;; Returns a list whose first item is a 3x3 transformation matrix and
;; second item the object insertion point in its parent (xref, block or space)
(defun refgeom ( ent / ang enx mat ocs )
    (setq enx (entget ent)
          ang (cdr (assoc 050 enx))
          ocs (cdr (assoc 210 enx))
    (list
        (setq mat
            (mxm
                (mapcar '(lambda ( v ) (trans v 0 ocs t))
                        (1.0 0.0 0.0)
                        (0.0 1.0 0.0)
                        (0.0 0.0 1.0)
                (mxm
                    (list
                        (list (cos ang) (- (sin ang)) 0.0)
                        (list (sin ang) (cos ang)     0.0)
                       '(0.0 0.0 1.0)
                    (list
                        (list (cdr (assoc 41 enx)) 0.0 0.0)
                        (list 0.0 (cdr (assoc 42 enx)) 0.0)
                        (list 0.0 0.0 (cdr (assoc 43 enx)))
        (mapcar '- (trans (cdr (assoc 10 enx)) ocs 0)
            (mxv mat (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx))))))
;; RevRefGeom (gile)
;; The inverse of RefGeom
(defun revrefgeom ( ent / ang enx mat ocs )
    (list
        (setq mat
            (mxm
                (list
                    (list (/ 1.0 (cdr (assoc 41 enx))) 0.0 0.0)
                    (list 0.0 (/ 1.0 (cdr (assoc 42 enx))) 0.0)
                    (list 0.0 0.0 (/ 1.0 (cdr (assoc 43 enx))))
                (mxm
                    (list
                        (list (cos ang)     (sin ang) 0.0)
                        (list (- (sin ang)) (cos ang) 0.0)
                       '(0.0 0.0 1.0)
                    (mapcar '(lambda ( v ) (trans v ocs 0 t))
                             (1.0 0.0 0.0)
                             (0.0 1.0 0.0)
                             (0.0 0.0 1.0)
        (mapcar '- (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx)))))
            (mxv mat (trans (cdr (assoc 10 enx)) ocs 0))
;; Matrix x Vector  -  Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
(defun mxv ( m v )
    (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
;; Matrix x Matrix  -  Vladimir Nesterovsky
;; Args: m,n - nxn matrices
(defun mxm ( m n )
    ((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n))
;; Matrix Transpose  -  Doug Wilson
(defun trp ( m )
    (apply 'mapcar (cons 'list m))
;; Block Name  -  Lee Mac
;; Returns the true (effective) name of a supplied block reference
(defun LM:blockname ( obj )
    (if (vlax-property-available-p obj 'effectivename)
        (defun LM:blockname ( obj ) (vla-get-effectivename obj))
        (defun LM:blockname ( obj ) (vla-get-name obj))
    (LM:blockname obj)
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
    (LM:endundo doc)
    (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
    (while (= 8 (logand 8 (getvar 'undoctl)))
        (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
(vl-load-com)
(princ
    (strcat
        "\n:: ChangeBlockBasePoint.lsp | Version 1.5 | \\U+00A9 Lee Mac "
        (menucmd "m=$(edtime,0,yyyy)")
        " www.lee-mac.com ::"
        "\n:: Available Commands:"
        "\n::    \"CBP\"  -  Retain Insertion Point Position"
        "\n::    \"CBPR\" -  Retain Block Reference Position"
(princ)
;;                             End of File                              ;;
marko_ribar
If I understood you correctly, you need this routine :
http://www.lee-mac.com/justifybasepoint.html
HTH., Regards, M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
emreakyazici
thank you so much.
