lisp returning Unknown command but still works?
Why is my lisp returning "Unknown command "SET". Press F1 for help."
Command: SET
ENTER DRAWING SETUP SCALE ... 96
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 200 objects audited
Auditing Entities Pass 2
Pass 2 200 objects audited
Auditing Blocks
4 Blocks audited
Auditing AcDsRecords
Total errors found 0 fixed 0
Erased 0 objects
(DEFUN C:Set()
(SETQ A (GETREAL "\nENTER DRAWING SETUP SCALE ... "))
(SETQ B (* A 0.09375))
(SETQ C (/ A 2))
(Setit)
(PRINC) )
(DEFUN Setit()
(COMMAND "-INSERT" "\\\\Cporldata\\trust\\Templates\\CP_Styles.dwg" "0,0,0" "1" "1" "0")
(COMMAND "-DIMSTYLE" "R" "CP Dim Style")
(COMMAND "-STYLE" "ARIAL NARROW" "ARIAL NARROW" "" "" "" "" "" "")
(COMMAND "TEXTSTYLE" "ARIAL NARROW")
(SETVAR "TEXTSIZE" B)
(SETVAR "DIMSCALE" A)
(SETVAR "LTSCALE" C)
(COMMAND "-INSERT" "\\\\cporldata\\autocad\\R2016\\Support\\Templates\\DWTs\\CP MleaderStyle.dwg" "0,0,0" "1" "1" "0")
(SETVAR "CMLEADERSTYLE" "CP")
(COMMAND "MLEADERSCALE" A "")
(COMMAND "AUDIT" "Y")
(COMMAND "REGEN")
(PRINC)
I am stupid.... had an extra "" on the
(COMMAND "-STYLE" "ARIAL NARROW" "ARIAL NARROW" "" "" "" "" "")
thanks....
rkmcswain
For one, this line does not need the "" (enter) at the end.
There is probably a similar error in another line somewhere.
thank you.
I am slow this morning and everything is now functioning well.
These boards are awesome because of folks like you taking the time to reply! Thank you for that.
