Lisp Question
Lisp Question
keshishian1
Lisp Question
keshishian1
I'm working on a LISP routine that should move all blocks named BB1, BB2, etc. to a layer called SDC-BUBBLES. However, the code below doesn’t seem to be functioning as expected. I'd really appreciate any suggestions ti make it work.
(defun c:MoveBlocksToLayer ( / ss i ent entData)
;; Select all block references named bb1 or bb2 from the drawing
(setq ss (ssget "_X" '((0 . "INSERT") (2 . "bb1,bb2"))))
;; If selection set is not empty, proceed
(if ss
(progn
(setq i 0) ;; Initialize counter
;; Iterate through all selected blocks
(repeat (sslength ss)
(setq ent (ssname ss i)) ;; Get the entity at index i
(setq entData (entget ent)) ;; Retrieve entity data list
;; Replace the layer (group 8) with "sdc-bubbles"
(setq entData (subst (cons 8 "sdc-bubbles") (assoc 8 entData) entData))
(entmod entData) ;; Apply the modified data to entity
(setq i (1+ i)) ;; Increment counter
(princ "\nBlocks moved to layer sdc-bubbles.") ;; Confirmation message
(princ) ;; Exit quietly
Also, I’d like to incorporate this into another routine I have (Print_SDC) so that everything runs in a single LISP command. Here's that additional code for reference that works fine.
(defun c:Print_SDC ()
(command "-LAYER" "OFF" "0-SDC-DYNAMIC-HIDE" "")
(command "HATCHTOBACK")
;; Define a list of layers to process
(setq layerList '("SDC-GRIDLINES" "SDC-PL" "SDC-BACKGROUND" "SDC-BACKGROUND-LIGHT" )) ; Add more layer names as needed
;; Loop through each layer and apply draw order
(foreach layerName layerList
(setq ss (ssget "X" (list (cons 8 layerName))))
(if ss
(command "._DRAWORDER" ss "" "_Back")
(princ)
;(initdia)
; (command "PLOT" "")
Thank You.
Moshe-A
@keshishian1 hi,
The lisp is ok except (entmod) function expect the properties (e.g layer, ltype) you use, should be exist. so to solve this add the code to search for the layer and if it does not exist, create it. if your blocks are dynamic, change the first line to this:
(setq ss (ssget "_X" '((0 . "INSERT") (2 . "`*U*,bb1,bb2"))))
to incorporate lisp command from another lisp, call it like any other lisp function:
(c:MoveBlocksToLayer)
Moshe
paullimapa
actually using subst & entmod if the layer does not exist, it'll create it automatically
Paul Li
IT Specialist
@The Office
Moshe-A
@paullimapa ,
OPPS paul, you are right 😀
since the program is ok, i guess dynamic blocks is the problem
here is the full fix
(defun c:MoveBlocksToLayer ( / ss i ent entData AcDbBlkRef)
 (if ss
  (progn
    (setq AcDbBlkRef (vlax-ename->vla-object ent))
    (if (wcmatch (strcase (vla-get-effectiveName AcDbBlkRef)) (strcase "bb1,bb2"))
     (progn
     ); progn
    ); if
    (vlax-release-object AcDbBlkRef)
   ); repeat
  ); progn
 ); if
paullimapa
Learned that from @Kent1Cooper
Paul Li
IT Specialist
@The Office
keshishian1
Thank You, this works fine and yes they are all dynamic blocks.
keshishian1
Thank You! This works great.
