LISP PROGRAMMER
LISP PROGRAMMER
lmoultonX6YLM
Message 1 of 8
LISP PROGRAMMER
lmoultonX6YLM
As per title. require a uk based programmer with expert knowledge for company project.
or point me in right direction where to hire one ?
Replies (7)
Message 2 of 8
ВeekeeCZ
Message 3 of 8
lmoultonX6YLM
Been trying to get hold of him, we have talked in past but currently not responding to messages.....:(
Message 4 of 8
hak_vz
https://www.k4cadsolutions.co.uk
https://jtbworld.com/  - Swedish based but works Worldwide
www.lee-mac.com/
https://www.upwork.com/hire/autolisp-developers/
For more details describe your project and what you need. Maybe you can receive good solution here on this forum.
Miljenko Hatlak
Message 5 of 8
diagodose2009
Do you need compile to many lisp.ascii.formats inside ascii.text.lsp?
Do you need self-debug format ascii.lsp before .FAS?
Do you need the program Self install inside Drawing.dwg?
You send PM on address attached/bellow
https://forums.autodesk.com/autodesk/attachments/autodesk/130/428346/1/nanocad2022lisp00.zip
Message 6 of 8
david.waight
Contact Andrew at Trucklesoft in Bristol, he only does .Net programming rather than lisp but he should be able to help you out unless it must be in Autolisp.
https://www.trucklesoft.co.uk/
Message 7 of 8
_Tharwat
I am available most of the time, so you can contact me as private message through this website or from mine as follows:
https://autolispprograms.wordpress.com/contact-us-2/
Message 8 of 8
Sea-Haven
See PM
