Error while reading log file in Scriptpro
phil.brown
phil.brown
So I run a lisp that is basic, looks like this;
zoom
extents
explode
all
-purge
all
N
Audit
y
qsave
close
Y
Saved as an .scr. Running in scriptpro seems to fail but if I open the drawing and copy and paste this script works a treat. Why would this be happening? The purge is pretty big and can take a while but increasing the timeout to 100 which was suggested in other posts doesn't seem to help. Over 100 files to process would be good if this worked.
Cheers!
pendean
Community Legend
Community Legend
How does it fail?
Is there an error message on the textscreen? or a pop-up?
Side note: are you an LT user by chance or providing this to LT users? Because you are not really deep-purging ('all' does not catch all, plus you only run it once when at least twice catches a lot more), you should AUDIT first and there are way better LISP routines (and free add-ins from the Autodesk app store) that do a way better job handling your desires task.
phil.brown
Thanks. Tells me a lot of I'm doing wrong. I know there is also better ways to do this. I guess my question was more why the basic command lines work in a drawing but not in ScriptPro.
Im using Civil 3D 2020, and the error from the log file is
[ Status summary ]
Failed
Error while reading log file for C:\GCC_Maps\3345-22.dwg
So Audit first and repeat the purge?, I have found that these files only one purge is needed as after one purge there isnt anything else left to purge.
Could you give me the name of the free-addins you mention and be happy to give those a try?
hmsilva
zoom
extents
explode
all
-purge
all
N
Audit
y
qsave
close
Y
Cheers!
@phil.brown  remove the CLOSE
SCRIPTPRO will close the dwg, to open the next one
Hope this helps,
Henrique
pendean
Community Legend
Community Legend
hmsilva
@phil.brown in my previous post I suggested removing the command 'CLOSE' from the script, but I didn't remember that the 'EXPLODE' command doesn't work in the same way in a script.
A way to get around this situation is to set the system variable 'QAFLAGS' to 1 before 'EXPLODE' command, and turn back 'QAFLAGS' to 0 after.
Rename the attached 'script.txt' to 'script.scr' and try it in Scriptpro to see if it works as expected.
Hope this helps,
Henrique
phil.brown
That seems to have worked. You legend!! Thanks.
