lisp program to set up typical layout tabs
Message 1 of 18
Hello, Im new to lisp and im trying to create a lisp program that goes through my typical layout tabs and sets up the layers to be frozen or thawed.
I would like to switch to each layout tab and set things up automatically
1. set to model space
2. thaw the layers needed
Leaving layer 1 on at all times for my border.
and skip error's if a layout tab is missing.
(setvar "ctab" "front elevation")(command "_.mspace")(command "vplayer" "f" "~1" "")(command "vplayer" "thaw" "e" "")
(princ))
(setvar "ctab" "rear elevation")(command "_.mspace")(command "vlayer" "f" "~1" "")(command "layer" "thaw" "er" "")
(princ))
(setvar "ctab" "right elevation")(command "_.mspace")(command "vlayer" "f" "~1" "")(command "-layer" "thaw" "es" "")
(princ))(ignore-errors)
Can anyone here help me to get started?  Thanks
Replies (17)
Message 2 of 18
ВeekeeCZ
try this...
Spoiler
(defun c:Test nil
  (if (member "front elevation" (layoutlist)) ; it's case sensitive
    (progn
      (if (= (getvar "cvport") 1) (command "_.mspace"))
      (command "_.vplayer"
	       "f" "~1" ""
	       "thaw" "e" "" "")
      (command "_.pspace")
  (if (member (strcase "Rear elevation") (mapcar 'strcase (layoutlist))) ; not case sensitive
    (progn
	       "f" "~1" ""
	       "thaw" "er" "" "")
  (if (member "right elevation" (layoutlist))
    (progn
	       "f" "~1" ""
	       "thaw" "es" "" "")
  (setvar "ctab" "Model")
  (princ)
The first example is case sensitive, the second is not.
Message 3 of 18
IT seems to work well, thanks a million. this will save major time
(defun c:Test nil
(if (member "FRONT ELEVATION" (layoutlist)) ; it's case sensitive
(progn
(setvar "ctab" "FRONT ELEVATION")
"f" "~1" ""
"thaw" "e" "" "")
(if (member (strcase "REAR ELEVATION") (mapcar 'strcase (layoutlist))) ; not case sensitive
(progn
(setvar "ctab" "REAR ELEVATION")
"f" "~1" ""
"thaw" "er" "" "")
(if (member "RIGHT ELEVATION" (layoutlist))
(progn
(setvar "ctab" "RIGHT ELEVATION")
"f" "~1" ""
"thaw" "es" "" "")
(setvar "ctab" "COVER")
(princ)
I like to stay in model space, and then go back to the cover once I have all layout tabs setup.  Awesome
Message 4 of 18
the next question would be, how do I thaw multiple layers?
(defun c:Test nil
(progn
"f" "~1" ""
"thaw" "e" "" "")
(progn
"f" "~1" ""
"thaw" "er" "" "")
(progn
"f" "~1" ""
"thaw" "es" "" "")
(if (member "1ST FLOOR PLAN" (layoutlist))
(progn
(setvar "ctab" "1ST FLOOR PLAN")
"f" "~1" ""
"thaw" "0" "" ""
"thaw" "2" "" "" )
(princ)
Message 5 of 18
ВeekeeCZ
Use a comma as delimiter.
"0,2"
Message 6 of 18
would it be possible to add a command to unlock all layers?
(progn
"f" "~1" ""
"thaw" "0,2" "" "")
Message 7 of 18
ВeekeeCZ
(progn
"f" "~1" ""
"thaw" "0,2" "" "")
(command "_.layer" "_unlock" "*" "") ; not inside of (if...) and once would be enough
It's not VP related, so use the regular layer command. You don't have to use dash in lisp even in autocad's command line you need it to evoke a command line version of a command.
Message 8 of 18
You really know your stuff.  I keep adding things to the script.
(if (member "COVER" (layoutlist)) ; it's case sensitive
(progn
"f" "~1" ""
"thaw" "COVER" "" "")
(command "-vports" "Lo" "on" "ALL" "")
(command "zoom" "e")
Would it be possible to have the left hand corner of the layout tab view at 0,0
And scale the drawing to 3/16" = 1" before I zoom extents?
Message 9 of 18
I'm still trying to get the lower left corner of the view port to stay at 0,0 when I zoom to scale.
(progn
"f" "~1" ""
(command "-vports" "Lo" "off" "ALL" "")
(command "zoom" (strcat "1/48" "" "XP")) ; = 1/4" scale viewport
Message 10 of 18
ВeekeeCZ
@Anonymous wrote:
I'm still trying to get the lower left hand corner of the view port to stay at 0,0 when I zoom to scale.
Good that you figured the zoom.
Then use PAN command. Calculation of the lower left corner is not that simple, but I think you can manage that too. The manual you can find HERE Use some variables and little math. Or use the spoiler - but there it's not that obvious.
Spoiler
(command "_.PAN" '(0 0 0) (mapcar '- (getvar 'VIEWCTR) (mapcar '(lambda (x) (* (getvar 'VIEWSIZE) 0.5 x)) (list (apply '/ (getvar 'SCREENSIZE)) 1))))
Message 11 of 18
Would the vla-put-center method be easier?
Message 12 of 18
ВeekeeCZ
I doubt it. You still need to count some point. Those five steps is not difficult to follow.
Message 13 of 18
This might take a week or two.. 🙂
;;VIEWSIZE = 41'-6 15/16" (read only)
;;VIEWCTR = 34'-1 1/16",21'-0 5/16",0'-0" (read only)
;;SCREENSIZE = 82'-1",51'-6" (read only)
Message 14 of 18
the conversion part is not explained? or is it?
Message 15 of 18
The DCS to WCS conversion seems complicated. And Capture.JPGI think that I had some things mixed up on my spreed sheet.
Message 16 of 18
ВeekeeCZ
You're right, it is... matrix calculation... But, if you don't rotate your viewport, you don't need it. Actually my solution from spoiler in post #10 does not include it. But if you decide to do that, we have simple built-in function for that HERE
I don't do how much you're adept with basic functions... so here are some hints...
step 1
Spoiler
(getvar), (setq), (trans)
step 4
Spoiler
(car) (last)
step 5
Spoiler
(list)
Message 17 of 18
Thanks again for helping me to write my routine that sets up my view ports to standard defaults. It saved me a lot of time today. I will work on the panning part of it this weekend. If I can't figure it out then that is ok too. I really don't think that I need it at this point.
Peace,, Nick
Message 18 of 18
all man ,, you actually gave me the code.. It takes awhile to click sometimes.  lol.  Smiley Very Happy
Spoiler
