I need to change a dwg from True North to Project North. To do this I was just going to declare the UCS and then use a lisp routine to rotate all of the dwg notes (multileaders) by 90 degrees. However, when I do this, the leader legs of the multileaders get messed up.
Rotating the multileader before or after the UCS change makes no difference in the result of the multileader behavior.
Any Ideas?
Attaching both the drawing and the batch rotate routine
