Lisp parse through Layout Tabs then Audit
mdhutchinson
Advisor Advisor
mdhutchinson
I could write this myself I suppose... but I was wondering if anyone might know of a lisp that will walk through all the layout tabs and perform an Audit Command on each.
As, it is my understanding that you can do Audit on each layout tab.
Isn't this the case?
rkmcswain
AFAIK, AUDIT is a document level command, although per the documentation it does "places the objects with errors that are in the current space into the Previous selection set."
jwhite
FWIW, the audit method requires the document object and not a layout object.
