Lisp para quatitativo
LuciLopes
Message 1 of 18
LuciLopes
Preciso de uma lisp que faça uma tabela com nome, área e perimetro de ambiente, essas coisas tem que ser editadas com fields quando eu quiser, alguém pode me ajudar (sobre o nome pode só enumerar e depois eu mudo o nome do ambiente)
Replies (17)
Message 2 of 18
ВeekeeCZ
Possibly this could help you.
http://www.lee-mac.com/lengthfield.html
Message 3 of 18
Sea-Haven
Post a dwg.
Message 4 of 18
LuciLopes
Pronto é exatamente essa lisp só que eu queria que fizesse uma planilha como essa lisp aqui:
Message 5 of 18
LuciLopes
Aqui
Message 6 of 18
hak_vz
Created according to your sample not using lee mac script.
Code asks you to select object on the layer where rooms borders (walls) are created and extracts its layer name.
It collects all closed polyline inside that layer and for each polyline in selection extracts its area perimeter(length) and coordinates. Inside polygon defined by this coordinates it search for a text (mtext) object inside same layer as selected polyline. Than it creates table from point you pick. Scale table according to your needs, I didn't put table styling inside code.
(defun c:LuciLopes ( / *error* take pointlist2d JH:list-to-table lay room_list room_name rooms_ss i spaceobject eo area len pts sst)
	(defun *error* (msg)
		(if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*"))
			(princ (strcat "\nOops an Error : ( " msg " ) occurred."))
		(princ)
	(defun take (amount lst / ret)(repeat amount (setq ret (cons (car lst) (take (1- amount) (cdr lst))))))
	(defun pointlist2d (lst / ret) (while lst (setq	ret (cons (take 2 lst) ret) lst (cddr lst))) (reverse ret))
;; JH:list-to-table --> Jonathan Handojo
;; Creates a table from a list of lists of strings
;; space - ModelSpace or Paperspace vla object
;; lst - list of lists where each list is a list of strings
;;	=> if you wish to insert a block in the cell, prefix using "<block>" followed by the block name
;;	=> e.x. if you want to insert the block "TestBlock1", input the string as "<block>TestBlock1"
;; pt - Insertion point of table (2 or 3 reals)
;; tblstyle - Table style to use
(defun JH:list-to-table (space lst pt tblstyle / i j lens ncols rows totlen txt vtable)
    (setq ncols (apply 'max (mapcar 'length lst))
	  vtable (vla-AddTable space (vlax-3d-point pt) (length lst) ncols 10 10)
    (vla-put-RegenerateTableSuppressed vtable :vlax-true)
    (vla-put-StyleName vtable tblstyle)
    (repeat (setq i (length lst))
	(setq rows (nth (setq i (1- i)) lst))
	(vla-SetRowHeight vtable i (* 2 (vlax-invoke vtable 'GetCellTextHeight i 0)))
	(repeat (setq j (length rows))
	    (setq lens
		     (cons
			     (abs
				 (apply '-
					(mapcar 'car
						(textbox
						    (list
							(cons 1 (setq txt (nth (setq j (1- j)) rows)))
							(cons 40 (vlax-invoke vtable 'GetCellTextHeight i j))
							(cons 7 (vlax-invoke vtable 'GetCellTextStyle i j))
			 lens
	    (if (eq (strcase (substr txt 1 7)) "<BLOCK>")
		(progn
		    (setq blk (substr txt 8))
		    (if (and
			     (wcmatch (getenv "PROCESSOR_ARCHITECTURE") "*64*")
			     (vlax-method-applicable-p vtable 'setblocktablerecordid32)
			 (vla-SetBlockTableRecordId32 vtable i j (vla-get-ObjectID (vla-item (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object))) blk)))
			 (vla-SetBlockTableRecordId vtable i j (vla-get-ObjectID (vla-item (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object))) blk)) :vlax-true)
		(vla-SetText vtable i j txt)
	(setq totlen (cons lens totlen) lens nil)
    (repeat ncols
	(vla-SetColumnWidth vtable (setq ncols (1- ncols))
	    (apply 'max
		   (vl-remove nil
		       (mapcar
			   '(lambda (x)
				(nth ncols x)
			   totlen
    (vla-put-RegenerateTableSuppressed vtable :vlax-false)
    vtable
	(setq doc (vla-get-activedocument (vlax-get-acad-object)))
	(setq spaceobject(if (eq (getvar 'cvport) 1)(vla-get-paperspace doc)(vla-get-modelspace doc)))
	(setq lay (cdr(assoc 8 (entget(car(entsel "\nSelect closed lwpolyline on layer whos entity areas needs to be extracted >"))))))
	(setq rooms_ss (ssget "_X" (list (cons 0 "lwpolyline")(cons 8 lay) (cons 70 1))))
	(cond
		((and rooms_ss)
			(setq i -1)
			(setq room_list (list))
			(setq room_list (append room_list (list(list "TABELA DE ÁREA"))))
			(setq room_list (append room_list (list(list "CÔMODO" "ÁREA" "PERIMETRO"))))
			(while (< (setq i (1+ i)) (sslength rooms_ss))
				(setq eo (vlax-ename->vla-object (ssname rooms_ss i)))
				(setq area (rtos (vlax-get eo 'Area)2 2) len (rtos(vlax-get eo 'Length)2 2))
				(setq pts (pointlist2d (vlax-get eo 'coordinates)))
				(setq sst  (ssget "wp" pts (list (cons 8 lay) (cons 0  "*TEXT"))))
				(setq room_name (cdr (assoc 1 (entget (ssname sst 0)))))
				(setq room_list (append room_list (list(list room_name area len))))
			(setq pt (getpoint "\nSelect table insertion point >"))
			(JH:list-to-table spaceobject room_list pt "standard")
			(princ "\nDone!")
	(princ)
Miljenko Hatlak
Message 7 of 18
Sea-Haven
Another. Hak_vz snuck in while I was thinking about it. Select text to isolate layers then pick text then outline so table is made in pick order.
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-para-quatitativo/td-p/12418577
(defun c:luci1 ( / CreateTableStyle luci txtht curspace oldsnap pt1 numrows numcolumns rowheight colwidth objtable ent obj)
(defun CreateTableStyle (txtht / dicts dictobj key class custobj )
;; Get the Dictionaries collection and the TableStyle dictionary
(setq dicts (vla-get-Dictionaries (vla-get-ActiveDocument(vlax-get-acad-object))))
(setq dictObj (vla-Item dicts "acad_tablestyle"))
(setq luci "No")
(vlax-for dname dictobj
  (if (=  (vla-get-name dname) "Lucilopes1" )
   (setq luci "found")
(if (= luci "No")
  (progn
  ;; Create a custom table style
  (setq key "Lucilopes1" class "AcDbTableStyle")
  (setq custObj (vla-AddObject dictObj key class))
  ;; Set the name and description for the style
  (vla-put-Name custObj "Lucilopes1")
  (vla-put-Description custObj "Lucilopes1 custom table style")
  ;; Sets the bit flag value for the style
  (vla-put-BitFlags custObj 1)
  ;; Sets the direction of the table, top to bottom or bottom to top
  (vla-put-FlowDirection custObj acTableTopToBottom)
  ;; Sets the horizontal margin for the table cells
  (vla-put-HorzCellMargin custObj (* txtht 0.5))
  ;; Sets the vertical margin for the table cells
  (vla-put-VertCellMargin custObj (* txtht 0.5))
  ;; Set the alignment for the Data, Header, and Title rows
  (vla-SetAlignment custObj (+ acDataRow acHeaderRow acTitleRow) acMiddleCenter)
  ;; Set the text height for the Title, Header and Data rows
  (vla-SetTextHeight custObj acDataRow txtht)
  (vla-SetTextHeight custObj acHeaderRow txtht)
  (vla-SetTextHeight custObj acTitleRow txtht)
  ;; Set the text height and style for the Title row
  (vla-SetTextStyle custObj (+ acDataRow acHeaderRow acTitleRow) "Standard")
(setvar 'ctablestyle "Lucilopes1")
(princ)
) ; CreateTableStyle
(setq txtht 0.2)
(CreateTableStyle txtht)
(setq oldsnap (getvar 'osmode))
(setvar 'osmode 0)
(setq curspace (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
(setq pt1 (vlax-3d-point (getpoint "\nPick point for top left hand of table:  ")))
(command "layiso" (cdr (entsel "\nPick text to isolate layer ")) "")
(setq txtht 0.2)
(setq numrows 3)
(setq numcolumns 3)
(setq rowheight 0.5)
(setq colwidth 2.5)
(setq objtable (vla-addtable curspace pt1 numrows numcolumns rowheight colwidth))
(vla-settext objtable 0 0 "TABELA DE ÁREA")
(vla-settext objtable 1 0 "CÔMODO")
(vla-settext objtable 1 1 "ÁREA")
(vla-settext objtable 1 2 "PERIMETRO")
(vla-Setcolumnwidth Objtable  0 3.2)
(vla-Setcolumnwidth Objtable  1 3.2)
(vla-Setcolumnwidth Objtable  2 3.2)
(VLA-SETrOWHEIGHT OBJTABLE 0 0.7)
(VLA-SETrOWHEIGHT OBJTABLE 1 0.7)
(VLA-SETrOWHEIGHT OBJTABLE 2 0.7)
(setq objtable (vlax-ename->vla-object (entlast)))
(setq numrows 2)
(while (setq ent (car  (entsel "Pick text Enter to exit ")))
  (setq obj (vlax-ename->vla-object ent))
  (vla-InsertRows Objtable  numrows (vla-GetRowHeight Objtable (1- numrows)) 1)
  (vla-setText Objtable numrows 0
       (strcat
         "%<\\AcObjProp Object(%<\\_ObjId "
           (vl-princ-to-string
             (vla-get-Objectid Obj))
               ">%).Textstring >%"))
  (setq obj (vlax-ename->vla-object (car  (entsel "Pick pline "))))
  (vla-setText Objtable numrows 1
       (strcat
           (vl-princ-to-string
               ">%).Area \\f \"%lu2%pr2\">%"))
  (vla-setText Objtable numrows 2
       (strcat
           (vl-princ-to-string
               ">%).length \\f \"%lu2%pr2\">%"))
  (setq numrows (1+ numrows))
(command "layuniso")
(setvar 'osmode oldsnap)
(princ)
(c:luci1)
Message 8 of 18
LuciLopes
no seu código tá ficando assim quando é utilizado
Message 9 of 18
LuciLopes
Por favor ajeita essa lisp porque ela tá muito boa mas essa parte do ### tá complicando a minha vida, essa lisp é exatamente o q eu quero.
Message 10 of 18
LuciLopes
tá dando esse erro:
Oops an Error : ( bad argument type: lselsetp nil ) occurred
eu testei em um projeto menor e deu certo, mas em um projeto maior com mais informações deu errado
Message 11 of 18
hak_vz
Copiei seu teste para ter 800 quartos e o código funciona bem. Antes de escolher o ponto de inserção da tabela, amplie para que todos os elementos fiquem visíveis e só então escolha o ponto. Quem pode ficar de pé se não houver nenhuma inscrição na sala. Eu tenho que testar. Principalmente. também funciona com 800 salas, basta dar um tempo porque é um código bastante exigente quando tem muitos elementos e gerar uma tabela não é fácil, espero que o google traduza bem.
Miljenko Hatlak
Message 12 of 18
LuciLopes
Okay, o problema não é no "TESTE" e sim em outro projeto que testei que tinha muitos elementos tipo: cotas, mtext, dtext, hatch. Eu acho que pelo comando identificar os MTEXT contidos na POLILYNE em TODO o projeto pode ser que dê realmente errado, preferia fazer um por um para ser opcional, ou ele fazer isso com elementos (MTEXT e POLILYNE) do mesmo LAYER. tomara que tenha me expressado bem.
Message 13 of 18
hak_vz
@LuciLopes
If you can assure that inside room boundary polylines there is only one text or mtext for room description, and on the same layer, code should work OK. For the areas and table creation you can have separate layer you can hide or erase when not needed. Also you can copy just that layer with boundaries and descriptions to new temporary drawing for easier checking. There you can check if some description text is missing.
Number of other elements inside the drawing doesn't matter. Just zoom whole drawing before you pick table insertion point. I will test the code later today, currently at work.
Miljenko Hatlak
Message 14 of 18
f_santana
@LuciLopes os ### indicam que precisa regenerar a TELA
FIELD inserido pro programação tem esta necessidade
Você achou uma postagem útil? Então fique à vontade para curtir essas postagens!
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão Aceitar Solução.
Fábio Santana
Architect | CAD/BIM Manager
Message 15 of 18
LuciLopes
eu to usando updatefield para para regenerar a tabela e mesmo assim não tá funcionando
Message 16 of 18
hak_vz
Corrected code for case there is no description text inside room boundary polyline.
Also you can create your own table style and change "standard" to its name inside
		(princ)
	    (setq lens
		     (cons
			     (abs
				 (apply '-
					(mapcar 'car
						(textbox
						    (list
			 lens
		(progn
		    (if (and
    (repeat ncols
	    (apply 'max
		   (vl-remove nil
		       (mapcar
			   '(lambda (x)
				(nth ncols x)
			   totlen
    vtable
	(cond
		((and rooms_ss)
			(setq i -1)
				(if (and sst)(setq room_name (cdr (assoc 1 (entget (ssname sst 0)))))(setq room_name " "))
			(setq pt (getpoint "\nZoom whole drawing and select table insertion point >"))
			(princ "\nDone!")
	(princ)
Miljenko Hatlak
Message 17 of 18
LuciLopes
RESOLVIDO! MUITO OBRIDAGA!!
Message 18 of 18
Sea-Haven
Not sure why your result. This is mine. Will try to work out why.
Is it a new dwg ?
