LISP or any program to Embed linked images already exists in drawing as Paintbrush pictures or Picture(metafile)
I have images in my AutoCAD drawing as linked images(Pasted directly). These drawing, while sharing, required to zip dwg file along with these pictures, other wise if I share only dwg file, it doesnt show these attached images. I need to place them as Paintbrush pictures or Picture(metafile) without again doing paste special command. Is there any way like AutoCAD command or LISP to do it?
Sea-Haven
It took me about 2 minutes Google "bind images to autocad"
Would I expect a LISP program instead:
Step might be similar to,
1.LISP need to find out selected image path, its scale & its coordinates in drawing
2.Then from that path do paste special as Picture(metafile)/Paintbrush pictures with same scale & on same coordinate in drawing
3.Then delete selected linked image.
Sea-Haven
When you normal paste an image you have its details so should be able to do with a lisp. Just look at the steps involved.
Just drag dropped an image and this is the important property ; ImageFile = "D:\\Screenshots\\Info-alanh.PNG"
