Hi all,
Was wondering, what could cause all the .lsp files to not load in the suitcase ?
I've been experiencing this.
Hi all,
Based on my experience, Items that were dragged to the suitcase will only take affect after you close the CAD session and should be the last session to be closed (where the dragging happened ) in case there are multiple sessions running at the same time .
What have you tested and ruled out so far @cyberflow
What about the basics like:
did you restart your PC yet?
Do the LISP actually work if you drag/drop a couple of them from the folder into an open session?
Is this a fresh new AutoCAD install or an old one with other issues?
Are all the LISP located in the TRUSTED FOLDER listing here?
