Lisp not loading when put in the suitcase in appload
cyberflow
Advisor Advisor
cyberflow
Hi all,
Was wondering, what could cause all the .lsp files to not load in the suitcase ?
I've been experiencing this.
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
pbejse
  • Lisp has an issue, ; error: malformed list as an example
  • Lisp file not found
  • There are duplicate command names are found on multiple lisp file
  • Or AutoCAD is just having a bad day 🙂
Based on my experience, Items that were dragged to the suitcase will only take affect after you close the CAD session and should be the last session to be closed (where the dragging happened ) in case there are multiple sessions running at the same time .
pendean
Community Legend
Community Legend
What have you tested and ruled out so far @cyberflow
What about the basics like:
did you restart your PC yet?
Do the LISP actually work if you drag/drop a couple of them from the folder into an open session?
Is this a fresh new AutoCAD install or an old one with other issues?
Are all the LISP located in the TRUSTED FOLDER listing here?
cyberflow
Well i had to complain and create a thread on this for it to function correctly !
Even verified everything and everything seems to function ok after closing and relaunching my Autocad.
Well, thank you everyone !
Frank Freitas
LinkedIn
