Lisp needed
Lisp needed
Message 1 of 8
Lisp needed
in this program is 3 mistake please help me to find them
Thanks!!
; the program selects the circles and changes their radius by half
(defun C:radius(/ OR_OPEN OR_CLOSE filter ss tent telem tcontent
telemupper n)
; retrieve the selection set containing both
; single and multiline text objects
(setq filter (list '(0 . "CIRCLE") )
ss (ssget "X" filter)
; iterate over the selection set
(setq n 0)
(repeat (ssname ss)
(setq tent (entget (sslength ss n)))
(print tent)
(setq telem (assoc 40 tent))
(print telem)
(setq tcontent (cdr telem))
(print tcontent)
(setq razan (/ tcontent 2))
(print razan)
(setq telemupper (cons 10 razan))
(print telemupper)
(setq tent (subst telemupper telem tent))
(print tent);
(entmod tent)
(setq n (1+ n))
(princ)
Replies (7)
Message 2 of 8
cadffm
your posting sounds like an exercise or test, are you not sure you're going to find the mistakes? How do you know that there are three?
It sounds curios for me?
Sebastian
Message 3 of 8
yeah is exercise
it's something with  bad SSGET list value
Message 4 of 8
doaiena
What is the object of this exercise? You want a program, that will reduce all selected circles' radius in half, or you want someone to check out the code you have posted, or you want to learn about how SSGET works? Or you need an entirely different function? Please be more exact with your question, in order to get the best advice possible.
Message 5 of 8
dlanorh
(defun C:radius(/ OR_OPEN OR_CLOSE filter ss tent telem tcontent telemupper n)
  (setq ss (ssget "X"  '((0 . "CIRCLE"))));<< minor error here, you don't need a filter variable overcomplicated
  (setq n 0)
  (repeat (sslength ss); was ssname should be sslength
    (setq tent (entget (ssname ss n))); was sslength should be ssname
    (print tent);entity list
    (print telem);circle radius assoc
    (print tcontent);circle radius value
    (print razan);half circle radius value
    (setq telemupper (cons 40 razan));No!!! razan is half the radius, (assoc 10) is the centre of the circle.
    (print telemupper)
    (setq tent (subst telemupper telem tent)); why complicate it with extra lines and variables? (setq tent (subst (cons 40 razan) (assoc 40 tent) tent))
    (print tent);
    (entmod tent)
    (setq n (1+ n))
  (princ)
;;(repeat (sslength ss)
;;    (setq tent (entget (setq ent (ssname ss n)))
;;          razan (/ (cdr (assoc 40 tent)) 2)
;;          tent (subst (cons 40 razan) (assoc 40 tent) tent)
;;          n (1+ n)
;;    (entmod tent)
;;    (entupd ent) ;update entity on screen
See above, my 2 cents worth is commented out below
I am not one of the robots you're looking for
Message 6 of 8
doaiena
I would go for this. It seems more compact and easier to read for me.
(setpropertyvalue (ssname ss ctr) "radius" (/ (getpropertyvalue (ssname ss ctr) "radius") 2))
(setq ctr (1+ ctr))
Message 7 of 8
dlanorh
(setq ctr (1+ ctr))
100% in agreement. Vanilla does my head in nowadays
for me it would be
(vlax-for obj (setq ss (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))
  (vla-put-radius obj (/ (vla-get-radius obj) 2))
(setq ss nil)
Message 8 of 8
doaiena
If i have already set somewhere in the lisp: (setq acaddoc (vla-get-activedocument (vlax-get-acad-object)))
Your vl solution is the way to go. Using visual lisp functions in a one-off case /without setting a few variables/, makes them a bit too long and hard to read in some cases.
