Lisp needed explode mirrored block and reblock
Does anyone out there have a lisp routine to RENAME and REBLOCK a MIRRORED BLOCK including
the ATTRIBUTE definitions.
I would like to be able to MIRROR a BLOCK
Select  the BLOCK
The routine would then EXPLODE the BLOCK, RENAME (with a suffix "-M") it and INSERT it.
Thanks for any help.
Robert E. Scragg
krzysztof.psujek
Hi, maybe consider to create dynamic block and ad to it flip parameter.
Then I think you could achieve what you want without any routines.
Chris
Hi, I thought of that but I don't think it helps. We use alot of 3D blocks to build up an assembly - we then mirror the assembly. When we go to create a view with VIEWBASE we don't have all of the assembly shown. This is because the blocks have been MIRRORED. Hopefully AUTODESK will fix it .........One day. Robert Scragg
