07:32 PM
- Mute
- Permalink
- Report
Hi all,
I have found this lisp in this forum but currently it does not allow me to have a multiple selection.
Quite new with this lisp stuff btw. Any ways to have this lisp modified to allow multitple selections?
;; BELTB.lsp
;; = change all Block Entities of definitions of a selected block and all
;; nested block definitions within it to the Layer of the Top-level Block
;; Kent Cooper, 18 November 2014
(vl-load-com)
(defun C:BELTB (/ *error* doc nametolist blkss inc blk lay blknames ent edata)
(defun *error* (errmsg)
(if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
(princ (strcat "\nError: " errmsg))
); if
(vla-endundomark doc)
(princ)
); defun - *error*
(defun nametolist (blk / blkobj blkname); get Block name and put it into list of names
(if (= (logand (cdr (assoc 70 (entget blk))) 4) 0) ; not an Xref
(progn
(setq
blkobj (vlax-ename->vla-object blk)
blkname
(vlax-get-property blkobj
(if (vlax-property-available-p blkobj 'EffectiveName) 'EffectiveName 'Name)
; to work with older versions that don't have dynamic Blocks
); ...get-property & blkname
); setq
(if
(not (member blkname blknames)); name not already in list
(setq blknames (append blknames (list blkname))); then -- add to end of list
); if
); progn
); if
); defun -- nametolist
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vla-startundomark doc); = Undo Begin
(if (setq blkss (ssget "_+.:S" '((0 . "INSERT")))); User selection of a Block/Minsert/Xref
(progn ; then
(setq
blk (ssname blkss 0); top-level Block insertion
lay (cdr (assoc 8 (entget blk))); Layer it's inserted on
); setq
(nametolist blk); put it in blknames list
(while (setq blk (car blknames)); as long as there's another Block name in list
;; done this way instead of via (repeat) or (foreach), so it can add nested Blocks' names to list
(setq ent (tblobjname "block" blk)); Block definition as entity
(while (setq ent (entnext ent)); then -- proceed through sub-entities in definition
(setq edata (entget ent)); entity data list
(if (member '(0 . "INSERT") edata) (nametolist ent)); if nested Block, add name to end of list
(entmod (subst (cons 8 lay) (assoc 8 edata) edata)); change to top-level Block's Layer
); while -- sub-entities
(setq blknames (cdr blknames)); take first one off
); while
(command "_.regen")
); progn
(prompt "\nNo Block(s) selected.")
); if [user selection]
(vla-endundomark doc); = Undo End
(princ)
); defunTIA
