lisp loaded shortcut command not working
Gaganpatel
Gaganpatel
 Dear Sir,
Lisp loaded shortcut command not working.
dlanorh
It might be easier to help if you posted the lisp in which the short cut doesn't work.
I am not one of the robots you're looking for
jayhar
AutoCAD LT version Appload does not works
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
roland.r71
A little (much) more info would be nice...
Like: WHAT (exactly) isn't working?
What (error) message do you get?
Does the lisp load?
Do you try to run a function from the commandline? if so, does the function start with C: ?
What does the lisp look like? (copy/paste or attach the code!)
etc.etc.etc.
By just saying "I have a problem", nobody will ever know WHAT problem.
Gaganpatel
Dear Sir,
keyboard all shortcut command is not working, only icon command is working.
jayhar
<<<<<<<keyboard all shortcut command is not working,>>>>>>>>
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Keyboa...
Gaganpatel
Thanks Sir
