How to convert any sublist to one list?
Exapmle:
(1 2 (3 4 (5) 6) 7 8 (9))
to
(1 2 3 4 5 6 7 8 9)
Exapmle:
to
(1 2 3 4 5 6 7 8 9)
(defun :plainlist (lin / :sub lout) (defun :sub (lin) (foreach e lin (if (listp e) (:sub e) (setq lout (cons e lout)))) (reverse lout)) (:sub lin))
>> (:plainlist '(1 2 (3 4 (5) 6) 7 8 (9)))
>> (1 2 3 4 5 6 7 8 9)
(defun flatten (lst)
(cond
((null lst) nil)
((atom (car lst))
(cons (car lst)
(flatten (cdr lst))))
(t (append
(flatten (car lst))
(flatten (cdr lst))))))
Another variant:
(defun flatten2 (lst)
(if (null lst)
nil
(flat2 lst)))
(defun flat2 (lst)
(cond ((null lst) (list nil))
((atom lst) (list lst))
(T (apply (function append)
(mapcar (function flat2)
lst)))))
Here's a cockamamie way to do it -- just take all the parentheses out:
(defun flatlist (oldlist / test str)
(setq test (open "C:/temp/junk.txt" "w")); <--EDIT filepath/name to suit
(prin1 oldlist test); puts into file AS TEXT STRING
(close test)
(setq
test (open "C:/temp/junk.txt" "r")
str (read-line test); bring text-string version in
(close test)
(while (wcmatch str "*(*") (setq str (vl-string-subst "" "(" str))); remove left parentheses
(while (wcmatch str "*)*") (setq str (vl-string-subst "" ")" str))); remove right parentheses
(setq newlist (read (strcat "(" str ")"))); put outer parentheses list wrapper back
(setq yourlist '(1 2 (3 4 (5) 6) 7 8 (9)))
Command: (flatlist yourlist)
(1 2 3 4 5 6 7 8 9)
And yes, in this case it's a real list of integers:
Command: (apply '+ newlist)
45
(setq otherlist '(1 (2 (3 (4 (5 6 7) (8 9))))))
Command: (flatlist otherlist)
(1 2 3 4 5 6 7 8 9)
(setq mylist '(1 "who" (3 4 ("what") 6) 7 "when" (9)))
Command: (flatlist mylist)
(1 "who" 3 4 "what" 6 7 "when" 9)
(setq anotherlist '(1.234 9.876 (5 4 3) "Marilyn Monroe" pi ("Yes" "No")))
Command: (flatlist anotherlist)
(1.234 9.876 5 4 3 "Marilyn Monroe" PI "Yes" "No")
And yes, PI there is the real symbol:
Command: (eval (nth 6 newlist))
3.14159
You could replace
with
(setq str (vl-string-translate "()" " " str))
Either way, this is a little risky: if the data contains strings with have parentheses inside, this will remove also those:
_$ (flatlist '(("A" "B+(C-D)")))
("A" "B+C-D")
_$ (flatten2 '(("A" "B+(C-D)"))) ;; or any of the list structure -based flatteners
("A" "B+(C-D)")
@martti.halminen wrote:
.... this is a little risky: if the data contains strings with have parentheses inside, this will remove also those: ....
Yes, that had occurred to me just after posting, and justifies my use of the adjective:
Besides, it takes more code to do it that way than some of the other approaches [maybe not so much under your (vl-string-translate) suggestion, though that adds extraneous spaces].
