Help with auto number with lisp
tencome
tencome
I am a new incomer just study lisp, ask for help.
1. First enter a total quantity a   (up to 9 numbers  (1,2,3^^^ 8,9) + 26 letters = up to 35) to automatically produce all numbers.
For example,
if  input a=5, you will output 1,2,3,4,5,
if input  a=12, output 1,2,3,4,5,6,7,8,9, A, B, C
2. The starting point coordinate is (0 0), and the spacing between each number and number is 100mm in X direction and 200mm in Y direction.
I didn't know how to modify below lisp to meet requirements.
(defun C:xh()
(setq a (getint "\ total quantity a"))
(setq n 1)
(setq x 100)
(while 1
(setq p '(0 0))
(command "text" "J""M" p 100 0 n)
(setq n (+ n 1))
hak_vz
(defun C:xh(/ )
(initget 7)
(setq maxval 35 i -1)
(setq p '(0 0))
(setq s '("1" "2" "3" "4" "5" "6" "7" "8" "9" "A" "B" "C" "D" "E" "F" "G" "H" "I" "J" "K" "L" "M" "N" "O" "P" "Q" "R" "S" "T" "U" "V" "W" "X" "Y" "Z"))
(cond
((<= a maxval)
(while (< (setq i (1+ i)) a)
	(command "_.text"  p 10 0 (nth i s) "")
	(setq p (mapcar '+ p '(100 200)))
(princ)
Miljenko Hatlak
Kent1Cooper
Here's a way to do it without spelling out a long list of 35 characters:
(defun C:TEST (/ a p asc)
  (while (or (not a) (> a 35))
    (initget 7); no Enter, no zero, no negative
    (setq a (getint "\nTotal quantity a {1 to 35}: "))
  ); while
  (setq
    p '(-100 -200)
    asc 48
  ); setq
  (repeat a
    (command "_.text"
      "_m" (setq p (mapcar '+ p '(100 200))) 100 0
      (chr (setq asc (+ asc (if (= asc 57) 8 1))))
    ); command
  ); repeat
  (princ)
); defun
It requires that the current Text Style does not have a fixed height.  You could build in the setting of the appropriate Style to ensure that, and if you want, make that a fixed-height Style and omit the 100 for the height in the Text command.
It asks again if you give it a number less than 1 or larger than 35.
Kent Cooper, AIA
tencome
Thank you very much.
tencome
Thank you very much, I need study it.
