LISP - layers draw order
clifford.c
clifford.c
I was looking for a lisp the automatically change the draw order of my layers. I found one but I still need to manually change the draw order of each layer. so I'm planning to start writing a LISP, while I don't have experience in LISP, hopefully my background in VBA helps.
This is what in my mind
let's say I have five layers (layer 1, layer 2, layer 3, layer 4 & layer 5)
I want a lisp that every time I run it, it will arrange the draw order of the layer in these order
Layer 3
Layer 2
Layer 5
Layer 1
Layer 4
can anyone show my how to write this code? Thank you
Accepted solutions (3)
clifford.c
So I use chatGPT to create a code. 😆 does not work. of course 🤣😂
(defun c:GPTorder ()
(setq layer-order '("Line" "Grass" "Road")) ; Set the desired layer order
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(setq layer-col (vla-get-layers doc))
(setq layer-list (vl-sort (mapcar 'vla-get-name layer-col) 'string<))
(setq layer-id-list (mapcar 'vla-get-objectid (vlax-invoke layer-col 'getitem layer-list)))
(setq sorted-layer-id-list (mapcar (lambda (x) (nth (1- (position (vla-get-name x) layer-list)) layer-id-list)) (sort layer-col '< :key (lambda (x) (position (vla-get-name x) layer-order))))) ; Sort the layer IDs according to the desired order
(vla-put-layers doc (vlax-make-safearray vlax-vbObject (reverse sorted-layer-id-list))) ; Set the new layer order
(vla-regen doc acAllViewports) ; Regenerate the drawing to update the display
(princ))
appreciate if anyone could help.
ronjonp
HERE is a good place to start.
Kent1Cooper
Something as simple as this?
(defun C:LAYORD ()
  (foreach lay '("Layer4" "Layer1" "Layer5" "Layer2" "Layer3"); top-most last
    (command "_.draworder" (ssget "_X" (list (cons 8 lay))) "" "_front")
  (prin1)
It assumes this is all happening in Model space, and you're in Model space at the time, and none of the Layers are locked.
Kent Cooper, AIA
ronjonp
@Kent1Cooper A simple IF will keep it from bombing if no selection is made.
(defun c:layord	(/ s)
  (foreach lay '("Layer4" "Layer1" "Layer5" "Layer2" "Layer3") ; top-most last
    (if	(setq s (ssget "_X" (list (cons 8 lay))))
      (command "_.draworder" s "" "_front")
  (prin1)
clifford.c
THANK YOU SO MUCH
