autolisp
autolisp
sudarsann
Message 1 of 8
autolisp
sudarsann
A Notepad having the many Dimensions of rectangles in the format of : "Length Width Height Desc".
(Ex: 36 24 65 aaaaa
48 30 72 bbbbb
the data having "tab space" between length, width, height and desc
I need to place the rectangles using length and width dimensons and also place the text inside the rectangles like
L: 36
W: 24
H: 65
Desc:aaaaa
I am trying to get the values individually but after getting 1st tab space value using the syntax (vl-string-search pattern string [start-pos]), I dont know how to get the remaining values of tab spaces.
I need help for solving the above problem?
Replies (7)
Message 2 of 8
Kent1Cooper
Post a small sample of such a file.  I know what a "tab" is, and what a "space" is, but not a "tab space."
Rectangles, or rectangular prisms [solid, with Z-axis-direction thickness]?
Kent Cooper, AIA
Message 3 of 8
paullimapa
One way is to use Lee Macs split string using space character as deliminater function to give you a list then you can extract the items from the list to place into the drawing
http://www.lee-mac.com/stringtolist.html
Paul Li
IT Specialist
@The Office
Message 4 of 8
Sea-Haven
A handy list of key codes.  Key codes (asawicki.info)
you can also do (ascii (getstring)) will show key number for most common keys, like
, : ; A-Z a-z 0-9
Message 5 of 8
sudarsann
Mr Kent,
Notepad having sample data.
Thank you
Sudarsan
Message 6 of 8
sudarsann
In AutoCAD need 2D rectangles and having text LENGTH x WIDTH x HEIGHT x DESCRIPTION inside the rectangles
In Notepad "tab" between LENGTH AND WIDTH and remaining data.
Message 7 of 8
Sea-Haven
The answer is easy but one more question how do you propose spacing the rectangs, maybe in a long pattern on X axis, or a grid pattern, so for say in a line what is gap ?
Message 8 of 8
komondormrex
that's it. draws rectangles in a raw with 10 units gap.
(defun c:draw_rectangle (/ txt_filename_full txt_id ml_point line_read rectangle_param_list)
	(defun string_to_list (input_string delimiter / delimiter_position output_list)
		(while (setq delimiter_position (vl-string-search delimiter input_string 0))
			(setq output_list (append output_list (list (substr input_string 1 delimiter_position)))
				  input_string (substr input_string (+ 2 delimiter_position))
		(append output_list (list input_string))
	(defun get_filename (extension / txt_filename)
			(if (type acet-ui-getfile)
					(setq txt_filename (acet-ui-getfile "Enter the name of TXT file"
									     extension
									     2
					(setq txt_filename (getfiled "Enter the name of TXT file"
								      extension
								      2
			(if (= "" txt_filename)
				nil
				txt_filename
	(defun draw_rectangle (_length _width _height _comment ml_point / rect_llc rect_ruc text_string)
		(setq rect_llc (list (car ml_point) (- (cadr ml_point) (* 0.5 (atof _width))))
		      rect_ruc (list (+ (car ml_point) (atof _length)) (+ (cadr ml_point) (* 0.5 (atof _width))))
		      text_string (strcat _length " x " _width " x " _height " x " _comment)
		(command "_rectang" "_non" rect_llc "_non" rect_ruc)
		(command "_text" "_j" "_mc" (mapcar '* '(0.5 0.5) (mapcar '+ rect_llc rect_ruc)) 2.5 0 text_string "")
	(if (and (setq txt_filename_full (get_filename "txt"))
		 (setq txt_id (open txt_filename_full "r"))
		(progn
			(setq ml_point (getpoint "\nPick left middle point for starting rectangle: "))
			(read-line txt_id)
			(while (setq line_read (read-line txt_id))
				(setq rectangle_param_list (string_to_list line_read "\t"))
				(draw_rectangle (car rectangle_param_list)
						(cadr rectangle_param_list)
						(caddr rectangle_param_list)
						(cadddr rectangle_param_list)
						ml_point
				(setq ml_point (list (+ (car ml_point) (atof (car rectangle_param_list)) 10) (cadr ml_point)))
			(close txt_id)
			(princ (strcat "File \"" txt_filename_full "\" has been read"))
	(princ)
