[LISP] How to check if a CAD command exists?
iBlachu
Message 1 of 10
iBlachu
How to check if a given CAD command exists?
Example.
I don't know if a given command called by COMMAND is called _-TOOLBAR or _-TOOLBARS.
So I want to check if one of the following expressions does not generate an error and which is correct:
(command "_-TOOLBAR" "MY" "_s")
(command "_-TOOLBARS" "MY" "_s")
How to check if the CAD command is called TOOLBAR or TOOLBARS?
This is just an example, but I mean the principle, is it possible to check it?
Replies (9)
Message 2 of 10
ВeekeeCZ
Possibly
(getcname "toolbar")
Message 3 of 10
iBlachu
Thank you, that's what I meant.
Message 4 of 10
Kent1Cooper
For (defun)'d custom command definitions, you can do this kind of thing:
(if C:YourCommandName
  (... do what you want ....); then
  (prompt "\nThat command is not defined."); else
Kent Cooper, AIA
Message 5 of 10
john.uhden
Or...
(type c:YourCommandName) will return
'LIST if it was defun-qed
'SUBR if it was defuned
'EXSUBR if it came from an ARX.
(At least I think that's the way it works)
John F. Uhden
Message 6 of 10
Sea-Haven
Same with plain defuns that have been loaded.
(type ah:getvalsm)
SUBR
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
Message 7 of 10
john.uhden
Sorry for the delay, Alan.
We were visiting my daughter & family in Maine.
What do you mean by a "plain defun?"
John F. Uhden
Message 8 of 10
Sea-Haven
No C: so its not a defun to be used when typed on command line. Rather called by lisp etc.
Yes can type (c:mydefun)
Message 9 of 10
vladimir_michl
If you mean an internal command, yes it can be checked by
(getcname "_-TOOLBAR")
But bear in mind it is not 100% reliable - some existing commands may return nil. E.g. MTEXT.
Vladimir Michl, www.arkance-systems.cz - www.cadforum.cz
Message 10 of 10
john.uhden
@iBlachu
I just remembered.  You could turn on LOGFILEMODE and run the ARX command, which will spit out a list (in doses like the LIST command) of all the AutoCAD (and vertical) commands, or only those that match a wild card pattern of your choice.  Then you could cut'n'paste the list into a text file or whatever.
John F. Uhden
