Concatenate Columns and Add custom header to Cable from/To Report
leonardo.alvarez4SZJL
I am using AutoCAD Electrical, Windows 10.
I'm trying to customize a Report with a User Post File and I am using this link as a good resource.
https://autodesk.typepad.com/systemsdesign/2014/08/customize-a-report-with-a-user-post-file.html
However I am not getting the desired output. 
I want to be able to combine LOC2 and PIN2. So that LOC2 holds the value and it will look like this.
"LCC L : 1X1"
Here is the code I wrote for it but it does not work once I select User Post on the bottom right and select third option.
      (if (= user_3 "1")
        (progn
          (setq rtrn '()) ; Start a new blank list to add
		  (foreach data wd_rdata ; look at each line in the report
			; pull out the 2 lines
			(setq LOC2 (nth 4 data))
			(setq PIN2 (nth 6 data))
			; string them together adding the space if non-blank
			(if (/= LOC2 "")
				(if (/= PIN2 "") (setq LOC2 (strcat LOC2 "" PIN2)))
				; else
				(setq LOC2 PIN2)
			; Plug this new value back in the LOC2 field using the supplied data
			(setq data (wd_nth_subst 4 LOC2 data))
			; Need to reverse the list since build it by adding on at the..
			(setq rtrn (reverse rtrn))
Can someone help and guide me in the right direction. I also would like to make a custom header as well. I have attached the .lsp and .cdl files.
So I was able to solve my issue. I was missing one line of code and also had another line miss placed.
Here is the fixed version:
      (if (= user_3 "1")
        (progn
			(if (/= LOC2 "")
				; else
				(setq LOC2 PIN2)
			; add this line of data into my new list as the first element
			(setq rtrn (cons data rtrn))
ronjonp
FWIW
;; This
(if (/= loc2 "")
  (if (/= pin2 "")
    (setq loc2 (strcat loc2 "" pin2))
  (setq loc2 pin2)
;; Could be this
(setq loc2 (if (/= loc2 pin2 "")
	     pin2
ВeekeeCZ
@ronjonp wrote:
FWIW
;; This
(if (/= loc2 "")
  (if (/= pin2 "")
  (setq loc2 pin2)
;; Could be this
	     pin2
Not the same result.
