Lisp help
Lisp help
Lisp help
I have been successful at adding these tools to my menu; Drawing Scale, Fasteners and Utility.
I have tried to add the path to all lisp and autocad drawings associated with these tools.
Would someone please let me know where the paths should be. I have been using these since R12.
Gary
imadHabash
Hi and welcome to AutoDesk Forum,
i suggest to use APPLOAD command then add your lisps  to the startup suite.
try it...
Imad Habash
Kent1Cooper
Would someone please let me know where the paths should be. ....
If I understand correctly:
Kent Cooper, AIA
Shneuph
Also, drawing and other support file paths should be added here. in the options menu.
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
scot-65
And yet another method (without the 'poor-mans' startup suite
and Support File Search Path):
Declare a hard path prefix(es) inside the S::STARTUP and store as a Gremlin(s).
I use %LPATH% (and %SPATH%), which stands for LISP Path (and SUPPORT Path).
"BLOCK Path" can be declared as well.
Now, inside the (CUI) Macro, if it is a Block:
^C^C-INSERT;(strcat %BPATH% "Detail01");...
As far as where to locate your library, I locate ours in the appdata\roaming
section. Why? If AutoCAD is uninstalled (or upgraded to a new release), my
customization is still there on the hard drive. Another possible location is
"C:\Program Files".
Reason being - For a complete uninstall of the AutoCAD product, the instructions
by Autodesk state to manually remove the "AutoCAD ####" folder that is found
in the appdata\roaming\Autodesk section. If your library is a sub-folder to this
folder, then your library will be lost (yup, happened here).
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
