Lisp gives duplicated key error while no duplicates are present
DGRL
Advisor Advisor
DGRL
Dear forum members
Thanks to @_gile for the time and afford helping me
I added 1 line to add custom props as well but the routine keeps giving back a automation error
; error: Automation Error. Duplicate key
The list that is use looks like this is only way longer
(("ISO_PIPESPEC" "n.v.t.1" "A" "b") ("ISO_MEDIUM" "n.v.t.2" "A" "b") ("ISO_DESIGN_PRESS" "n.v.t.3" "A" "b"))
The variable that holds the list is vier
This is the script I use.
Below script I have more info
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (setq dwgprop (vla-get-summaryinfo(vla-get-activedocument(Vlax-get-acad-object))))
  (vla-endundomark doc)
  (vla-startundomark doc)
  ;; iterate the block table
  (vlax-for blk (vla-get-blocks doc)
    (if (= :vlax-false (vla-get-isxref blk))
      (progn
        (vlax-for obj blk
          (if (and (= "AcDbAttributeDefinition" (vla-get-objectname obj))
                   (setq new (assoc (vla-get-tagstring obj) vier))
            (progn
              ;; rename the tag and prompt of the ATTDEF
              ;(vla-put-tagstring obj (cadr new)) ;(princ new)
              ;(vla-put-textstring obj (cadddr new)) ;(princ new)
              ;(vla-put-promptstring obj (caddr new)) ;(princ new)
             ;(vla-addcustominfo obj (cadr new)(cadddr new))
     (vla-addcustominfo dwgprop (cadr new)(cadddr new))
             ;(vla-addcustominfo(vla-get-summaryinfo(vla-get-activedocument(Vlax-get-acad-object)))(cadr new)(cadddr new))
              (setq name (vla-get-Name blk))
        ;; ATTSYNC the inserted references
        (if (= name (vla-get-Name blk))
          (command "_.ATTSYNC" "_Name" name)
  );end vlax-for blk
  (princ)
The  TAG / TEXT and PROMPSTRING are working fine
The addcustominfo gives back the error
What am I doing wrong here?
If this was of any help please kudo and/or Accept as Solution
Kind Regards
cadffm
vla-addcustominfo CREATE a new custominfo
If you create "ABC" and you try to create a new custominfo with the same name you get an error,
because customInfo Tag have to unique.
What you have to do is:
1. Check if your customInfo still exist,
2. if not existing create a new custominfo -> vla-addcustominfo
3. if your wanted custimInfo allready exist, change only the value of this custominfo -> vla-setCustomByKey
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-ActiveX/files...
Sebastian
DGRL
HI @cadffm
Thanks for the info will read it
I just added this after the end of vlax-for blk and before (vla-endundomark doc) and works perfect
(foreach att vier (vla-addcustominfo dwgprop (cadr att)(caddr att)))
Kind Regards
