Lisp for viewport works, but not 100% correct. After loading again, problem solved.
sander.van.pelt
sander.van.pelt
Hello everyone,
I have been using the lisp below for many years. This lisp creates 2 commands that allow me to lock and unlock the displays of the viewports. He also puts them in the "viewports" layer and sets them to "do not plot". But in addition to these tasks, it also gives them a color. The locked displays/viewports turn green and the unlocked ones turn red.
This so that I can clearly see which viewports are locked and do not accidentally work/zoom in and out in an unlocked viewport so that the scale and the view are no longer correct.
When I start AutoCAD or a new drawing, the lisp still works, but when I execute the command "VPL" (viewport lock) the viewport window no longer turns green but white. But with "VPU" (viewport unlock) the viewport does turn red.
If I then reload the lisp, it works as it should.
So if I then draw a viewport, it will first be placed in the current layer with the color of that layer and if I then use VPU or VPL, it will be in the viewports layer, will not be printed and will have a red or green color.
But why do I have to reload it every time I restart AutoCAD?
The lisp is simply in Startup Suite
(vl-load-com)
(defun dxf (n ed) (cdr (assoc n ed)))
(defun c:vpl (/ AD COUNT ENT I PL SS TABNAME VP VPNO)
    (setq ad (vla-get-activedocument (vlax-get-acad-object)))
(COMMAND "-LAYER" "N" "Viewport" "" "")
(COMMAND "-LAYER" "U" "Viewport" "" "")
(COMMAND "-LAYER" "PLOT" "N" "Viewport" "")
(COMMAND "-LAYER" "ON" "Viewport" "")
    (vlax-for lay (vla-get-layouts ad)
        (if (/= (setq TabName (strcase (vla-get-name lay))) "MODEL") ;_ end of /=
            (progn
                (if (setq ss (ssget
                                 "X"
                                 (list (cons 0 "viewport")
                                 ) ;_ end of list
                             ) ;_ end of ssget
                    ) ;_ end of setq
                    (progn
                        (setq count (sslength ss))
                        (setq i 0)
                        (if (> count 0)
                            (progn
                                (while (< i count)
                                    (setq
                                        ent (ssname ss
                                                    i
                                            ) ;_ end of ssname
                                    ) ;_ end of setq
                                    (setq vpNo
                                             (dxf
                                                 69
                                                 (entget
                                                     ent
                                                 ) ;_ end of entget
                                             ) ;_ end of dxf
                                    ) ;_ end of setq
                                    (if (> vpNo 1)
                                        (progn
                                            (setq vp (vlax-ename->vla-object
                                                         ent
                                                     ) ;_ end of vlax-ename->vla-object
                                            ) ;_ end of setq
                                            (if (= (vla-get-clipped
                                                       vp
                                                   ) ;_ end of vla-get-clipped
                                                   :vlax-false
                                                ) ;_ end of =
                                                (progn
                                                    (vla-put-color
                                                        vp
                                                        3
                                                    ) ;_ end of vla-put-color
                                                    (vla-put-layer
                                                        vp
                                                        "Viewport"
                                                    ) ;_ end of vla-put-layer
                                                ) ;_ end of progn
                                                (progn
                                                    (setq
                                                        pl (entget
                                                               (dxf
        340
        (entget
        ent
        ) ;_ end of entget
                                                               ) ;_ end of dxf
                                                           ) ;_ end of entget
                                                    ) ;_ end of setq
                                                    ;get clip entity
                                                    (setq pl (vlax-ename->vla-object
        (dxf -1
        pl
        ) ;_ end of dxf
                                                    ) ;_ end of setq
                                                    (vla-put-color
                                                        pl
                                                        3
                                                    (vla-put-layer
                                                        pl
                                                        "Viewport"
                                                    (vla-put-color
                                                        vp
                                                        3
                                                    (vla-put-layer
                                                        vp
                                                        "Viewport"
                                                ) ;_ end of progn
                                            ) ;_ end of if
                                            (vla-put-displaylocked
                                                vp
                                                :vlax-true
                                            ) ;_ end of vla-put-displaylocked
                                            (vla-update vp)
                                        ) ;_ end of progn
                                    ) ;_ end of if
                                    (setq i (1+ i))
                                ) ;_ end of while
                            ) ;_ end of progn
                        ) ;_ end of if
                    ) ;_ end of progn
                ) ;_ end of if
            ) ;_ end of progn
        ) ;_ end of if
    ) ;_ end of vlax-for
) ;_ end of defun
(defun c:vpu (/ AD COUNT ENT I PL SS TABNAME VP VPNO)
            (progn
                (if (setq ss (ssget
                                 "X"
                                 ) ;_ end of list
                             ) ;_ end of ssget
                    ) ;_ end of setq
                    (progn
                        (setq i 0)
                        (if (> count 0)
                            (progn
                                (while (< i count)
                                    (setq
                                        ent (ssname ss
                                                    i
                                            ) ;_ end of ssname
                                    ) ;_ end of setq
                                    (setq vpNo
                                             (dxf
                                                 69
                                                 (entget
                                                     ent
                                                 ) ;_ end of entget
                                             ) ;_ end of dxf
                                    ) ;_ end of setq
                                    (if (> vpNo 1)
                                        (progn
                                                         ent
                                            ) ;_ end of setq
                                                       vp
                                                   :vlax-false
                                                ) ;_ end of =
                                                (progn
                                                    (vla-put-color
                                                        vp
                                                        1
                                        ; 3 green
                                                    (vla-put-layer
                                                        vp
                                                        "Viewport"
                                                ) ;_ end of progn
                                                (progn
                                                    (setq
                                                        pl (entget
                                                               (dxf
        340
        (entget
        ent
        ) ;_ end of entget
                                                               ) ;_ end of dxf
                                                           ) ;_ end of entget
                                                    ) ;_ end of setq
                                                    ;get clip entity
        (dxf -1
        pl
        ) ;_ end of dxf
                                                    ) ;_ end of setq
                                                    (vla-put-color
                                                        pl
                                                        1
                                                    (vla-put-layer
                                                        pl
                                                        "Viewport"
                                                    (vla-put-color
                                                        vp
                                                        1
                                        ; 3 green
                                                    (vla-put-layer
                                                        vp
                                                        "Viewport"
                                                ) ;_ end of progn
                                            ) ;_ end of if
                                                vp
                                                :vlax-false
                                            (vla-update vp)
                                        ) ;_ end of progn
                                    ) ;_ end of if
                                    (setq i (1+ i))
                                ) ;_ end of while
                            ) ;_ end of progn
                        ) ;_ end of if
                    ) ;_ end of progn
                ) ;_ end of if
            ) ;_ end of progn
        ) ;_ end of if
Moshe-A
@sander.van.pelt  hi,
i do not see the issue you are talking about maybe you have other lisps interfering?
do a test, remove from appload startup suite other lisps (suspend acad.lsp acaddoc.lsp)
Moshe
