Lisp for total line length for lines which in every separately box
mss_selcukuni
Message 1 of 54
mss_selcukuni
Hi Everyone,
I want to make this with lisp in Autocad...
I want to export totale line lenght to excel table..
but i want to see lenght of lines with their box name with lenght..
Pls see example in attachment,
Replies (53)
Message 41 of 54
mss_selcukuni
@CADaSchtroumpf Hi,
in the past time, i tried code.. But i realized that code doesnt work true... Area datas not true..
Please see attachments..
Message 42 of 54
CADaSchtroumpf
@mss_selcukuni
An oversight on my part:
Lines do not have the Area property.
I added after line 18 (setq area 0.0) in the condition in the code of post 39 which I updated.
Please reload this code.
Thanks for checking and feed back!
Message 43 of 54
mss_selcukuni
Thank you @CADaSchtroumpf ,
it seems to work truely. thank you..
Message 44 of 54
mss_selcukuni
@CADaSchtroumpf
if any line (or any shape) passing over the box which we select.. Code isnt including this pass over line in the calculation...
in complex drawings, we can meet situation like this..
Cant we including these lines?
pls see attachments..
Drawing 2 is basic sample..
Drawing 22 is more complex sample then drawing 2
Message 45 of 54
CADaSchtroumpf
I am not available this week, please wait
Message 46 of 54
CADaSchtroumpf
@mss_selcukuni  a écrit :
@CADaSchtroumpf
@mss_selcukuni
Your request becomes complex...
If I was able to do anything with the "Drawing22.dwg", there are still problems.
I have treated only polylines. I manage to cut them at the limits of the box but the result in Excel is not always good.
The resulting lengths are allway correct, but the surfaces for the cut polylines are wrong.
For example in the "BOX 2" for the layer "Wall_Painting" and "Floor_Parquet" the original polyline will become two portions of distinct polylines whose surfaces will no longer mean anything.
You will have to resume these surfaces manually because I cannot solve this by programming (join the two portions by one or more segments in order to obtain a single polyline (closed or not: it does not matter) and to have the good area.
I hope this will still be able to help you because I for my part could not go further.
(vl-load-com)
(defun add_vtx (obj add_pt ent_name / bulg)
  (vla-addVertex
    obj
    (1+ (fix add_pt))
    (vlax-make-variant
      (vlax-safearray-fill
        (vlax-make-safearray vlax-vbdouble (cons 0 1))
          (list
            (car (trans (vlax-curve-getpointatparam obj add_pt) 0 ent_name))
            (cadr (trans (vlax-curve-getpointatparam obj add_pt) 0 ent_name))
  (setq bulg (vla-GetBulge obj (fix add_pt)))
  (vla-SetBulge obj
    (fix add_pt)
      (sin (/ (* 4 (atan bulg) (- add_pt (fix add_pt))) 4))
      (cos (/ (* 4 (atan bulg) (- add_pt (fix add_pt))) 4))
  (vla-SetBulge obj
    (1+ (fix add_pt))
      (sin (/ (* 4 (atan bulg) (- (1+ (fix add_pt)) add_pt)) 4))
      (cos (/ (* 4 (atan bulg) (- (1+ (fix add_pt)) add_pt)) 4))
  (vla-update obj)
(defun break_lw (js js_b / i tmp_name tmp_obj ent obj vrt_pt pt lst_pt dxf_obj xd_l dxf_43 dxf_38 dxf_39 dxf_10 dxf_40 dxf_41 dxf_42 dxf_39 dxf_210 n_vtx l)
  (cond
    ((and js js_b)
      (setq
        tmp_name (ssname js_b 0)
        tmp_obj (vlax-ename->vla-object tmp_name)
      (repeat (setq i (sslength js))
        (setq
          ent (ssname js (setq i (1- i)))
          obj (vlax-ename->vla-object ent)
          vrt_pt (vlax-variant-value (vla-IntersectWith obj tmp_obj 0))
        (if (>= (vlax-safearray-get-u-bound vrt_pt 1) 0)
          (progn
            (setq pt (vlax-safearray->list vrt_pt))
            (if pt
              (if (> (length pt) 3)
                (repeat (/ (length pt) 3)
                  (setq lst_pt (cons (list (car pt) (cadr pt) (caddr pt)) lst_pt) pt (cdddr pt))
                (setq lst_pt (cons pt lst_pt))
        (setq dxf_10 (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget ent))))
        (if (and lst_pt (listp lst_pt))
          (foreach el lst_pt
            (if (not (member T (mapcar '(lambda (x) (equal (list (car el) (cadr el)) x 1E-8)) dxf_10)))
              (add_vtx obj (vlax-curve-getparamatpoint obj (vlax-curve-getClosestPointTo obj el)) ent)
        (setq
          dxf_obj (entget ent (list "*"))
          xd_l (assoc -3 dxf_obj)
        (if (cdr (assoc 43 dxf_obj))
          (setq dxf_43 (cdr (assoc 43 dxf_obj)))
          (setq dxf_43 0.0)
        (if (cdr (assoc 38 dxf_obj))
          (setq dxf_38 (cdr (assoc 38 dxf_obj)))
          (setq dxf_38 0.0)
        (if (cdr (assoc 39 dxf_obj))
          (setq dxf_39 (cdr (assoc 39 dxf_obj)))
          (setq dxf_39 0.0)
        (setq
          dxf_10 (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) dxf_obj))
          dxf_40 (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 40)) dxf_obj))
          dxf_41 (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 41)) dxf_obj))
          dxf_42 (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 42)) dxf_obj))
          dxf_210 (cdr (assoc 210 dxf_obj))
        (if (not (zerop (boole 1 (cdr (assoc 70 dxf_obj)) 1)))
          (setq
            dxf_10 (append dxf_10 (list (car dxf_10)))
            dxf_40 (append dxf_40 (list (car dxf_40)))
            dxf_41 (append dxf_41 (list (car dxf_41)))
            dxf_42 (append dxf_42 (list (car dxf_42)))
        (setq lst_pt (reverse (mapcar '(lambda (x) (list (car (trans x 0 ent)) (cadr (trans x 0 ent)))) lst_pt)))
        (repeat (length lst_pt)
          (setq n_vtx -1 l nil)
          (if (vl-position T (mapcar '(lambda (x) (equal x (car lst_pt) 1E-8)) dxf_10))
            (entmake
              (append
                (list
                  (cons 0 "LWPOLYLINE")
                  (cons 100 "AcDbEntity")
                  (assoc 67 dxf_obj)
                  (assoc 410 dxf_obj)
                  (assoc 8 dxf_obj)
                  (if (assoc 62 dxf_obj) (assoc 62 dxf_obj) (cons 62 256))
                  (if (assoc 6 dxf_obj) (assoc 6 dxf_obj) (cons 6 "BYLAYER"))
                  (if (assoc 370 dxf_obj) (assoc 370 dxf_obj) (cons 370 -1))
                  (cons 100 "AcDbPolyline")
                  (cons 90 (1+ (vl-position T (mapcar '(lambda (x) (equal x (car lst_pt) 1E-8)) dxf_10))))
                  (cons 70 (boole 1 (cdr (assoc 70 dxf_obj)) 128))
                  (cons 38 dxf_38)
                  (cons 39 dxf_39)
                (reverse
                  (repeat (1+ (vl-position T (mapcar '(lambda (x) (equal x (car lst_pt) 1E-8)) dxf_10)))
                    (setq l
                      (append
                        (list
                          (cons 42 (nth (1+ n_vtx) dxf_42))
                          (cons 41 (nth (1+ n_vtx) dxf_41))
                          (cons 40 (nth (1+ n_vtx) dxf_40))
                          (cons 10 (nth (setq n_vtx (1+ n_vtx)) dxf_10))
                        l
                (list (assoc 210 dxf_obj))
                (if xd_l (list xd_l) '())
          (repeat n_vtx
            (setq dxf_10 (cdr dxf_10) dxf_40 (cdr dxf_40) dxf_41 (cdr dxf_41) dxf_42 (cdr dxf_42))
          (setq lst_pt (cdr lst_pt))
        (entmake
          (append
            (list
              (assoc 67 dxf_obj)
              (assoc 410 dxf_obj)
              (assoc 8 dxf_obj)
              (cons 90 (length dxf_10))
              (cons 38 dxf_38)
              (cons 39 dxf_39)
            (reverse
              (repeat (length dxf_10)
                (setq l
                  (append
                    (list
                    l
        (entdel ent)
(defun PolylineByLayer (l_pt ss_b / ss i pline ename layer len area lst sub)
  (if (setq ss (ssget "_CP" l_pt (append (list '(0 . "LWPOLYLINE") '(-4 . "<NOT") '(8 . "Box*,0") '(-4 . "NOT>") (cons 410 (getvar "CTAB"))))))
    (progn
      (break_lw ss ss_b)
      (if (setq ss (ssget "_WP" l_pt (append (list '(0 . "LWPOLYLINE") '(-4 . "<NOT") '(8 . "Box*,0") '(-4 . "NOT>") (cons 410 (getvar "CTAB"))))))
        (repeat (setq i (sslength ss))
          (setq
            pline (ssname ss (setq i (1- i)))
            ename (vlax-ename->vla-object pline)
            layer (cdr (assoc 8 (entget pline)))
          (if (vlax-property-available-p ename 'Length)
            (setq len (vlax-get ename 'Length))
            (setq len 0.0)
          (if (vlax-property-available-p ename "Area")
            (setq area (vlax-get ename 'Area))
            (setq area 0.0)
          (setq lst
            (if (setq sub (assoc layer lst))
              (subst (list layer (1+ (cadr sub)) (+ (caddr sub) len) (+ (cadddr sub) area)) sub lst)
              (cons (list layer 1 len area) lst)
(defun WriteExcel (data / xlApp wBook cells i j)
  (setq
    xlApp (vlax-create-object "Excel.Application")
    wBook (vlax-invoke-method (vlax-get-property xlapp 'WorkBooks) 'Add)
    cells (vlax-get-property xlApp 'Cells)
    i 0
  (foreach row data
    (setq i (1+ i) j 0)
    (foreach val row
      (setq
        j (1+ j)
        cell (vlax-variant-value (vlax-get-property cells 'Item i j))
      (vlax-put-property cell 'Value2 val)
  (vlax-invoke-method
    (vlax-get-property
      (vlax-get-property xlApp 'ActiveSheet)
      'Columns
    'AutoFit
  (vlax-put-Property xlApp 'Visible :vlax-true)
(defun c:boxinfo ( / areaname ss_box ename dxf_ent lpt data)
  (while (/= (setq areaname (getstring "\nArea name >")) "")
    (princ "\nSelect selection boundary")
    (while (null (setq ss_box (ssget "_+.:E:S" '((0 . "LWPOLYLINE")))))
      (princ "\nOject isn't valide")
    (setq ename (ssname ss_box 0))
    (vla-Offset (vlax-ename->vla-object ename) -1.0)
    (setq
      dxf_ent (entget (entlast))
      lpt (mapcar '(lambda (x) (trans x ename 0)) (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) dxf_ent)))
    (entdel (entlast))
    (setq data (append (mapcar '(lambda (x) (cons areaname x))(PolylineByLayer lpt ss_box)) data))
  (if data (WriteExcel (cons (list "Box name" "Layer" "Item" "Length" "Area") data)))
  (prin1)
Message 47 of 54
mss_selcukuni
Hi @CADaSchtroumpf,
Thank you so much... I have tried the last code.It seems good working. But there is a little diffrence. Please see table below..
1) Cells which is green colors are true but is red colors are false..
2) On the other hand, i dont understand but, code hasn't calculate with "layer 0"... please see below.
3) and, like you said, code hasn't worked with "lines" or "circles".. Can we add lines? this is so difficulty for us?
4) and another, while code is running, it is adding vertexes automaticly (i think for seperate polylines to boxes) but then code is calculating vertexes as item on excel.. I think this is reason of the wrong item-count (6) which is in article 1..
I have added sample in attechment...
can we check these 4 articles together please?
Message 48 of 54
CADaSchtroumpf
Hi @mss_selcukuni
This is normal, because to calculate by box, I have to cut the polylines; which creates additional elements.
For layer "0" I deliberately omitted it, to change it back in line 187 and 190:
change '(8 . "Box*,0") by '(8 . "Box*")
I remind you that the lines will not be taken into account in this latest version and that your boxes must be in a layer "Box???".
For me the development stops here, because your request becomes very complex, particular and requires too much time for a very specific use.
However, if you strive to continue this development, help can be provided, but a turnkey code cannot be provided.
Message 49 of 54
mss_selcukuni
ok.. Thank you so so much...
But i think it is important that including line type items in calculation..
Would you add this feature in code please? is it hard and complex?
Message 50 of 54
mss_selcukuni
I want to consider of LINE in calculation. I couldn't add this feature..
Please can you help me to this...
Message 51 of 54
CADaSchtroumpf
I integrated the lines
I tried to eliminate creating polyline and line that have zero length. (In the drawing provided there were a lot of them, certainly due to the use of the code provided previously which did not verify this)
My remarks made in message 46 concerning area and items remain valid.
Message 52 of 54
mss_selcukuni
Dear @CADaSchtroumpf,
Thank you so so much.. LISP is working very well.. Thank you...
Message 53 of 54
aaron_gonzalez
Allan, can you help me, please
this massage appear aftes load the lisp
"; error: bad argument type: stringp nil"
Message 54 of 54
Sea-Haven
The excel lisp has multiple functions in side it that you would copy out and use in YOUR code it is not a load all program. It is an advanced user program but once understood is simple to use. It sounds like you would have been better to PM me with what your trying to do.
