Lisp for total line length for lines which in every separately box
mss_selcukuni
Message 1 of 54
mss_selcukuni
Hi Everyone,
I want to make this with lisp in Autocad...
I want to export totale line lenght to excel table..
but i want to see lenght of lines with their box name with lenght..
Pls see example in attachment,
Replies (53)
Message 21 of 54
mss_selcukuni
Dear @hak_vz;
I'm so sorry... 😞
I hope you get well soon.. I wish we can did our lisp to finaly.
dont forget me pls..
Message 22 of 54
mss_selcukuni
@hak_vz,
Are you here my friend?
Message 23 of 54
mss_selcukuni
Hi Everyone...
Thank you to @hak_vz  for this perfect code..
This is wonderful for me..
But @hak_vz X is take caring of with health issues.. I whis He will be good and come here again soon..
I putted example documents (excel and Autocad).
Can you add addition to code to seperate layer name...
I want to seperate to different rows with by layer name in addition by box name..
can you help me please?
Message 24 of 54
CADaSchtroumpf
You can try this : press Enter at prompt "Area name >" for quit the loop and finish the job
(defun PolylineByLayer (l_pt / ss i pline layer value lst sub)
  (if (setq ss (ssget "_WP" l_pt (append (list '(0 . "LWPOLYLINE,LINE") (cons 410 (getvar "CTAB"))))))
    (repeat (setq i (sslength ss))
      (setq pline (ssname ss (setq i (1- i)))
        layer (getpropertyvalue (getpropertyvalue pline "LayerId") "Name")
        value (getpropertyvalue pline "Length")
      (setq lst
        (if (setq sub (assoc layer lst))
          (subst (list layer (1+ (cadr sub)) (+ (caddr sub) value)) sub lst)
          (cons (list layer 1 value) lst)
(defun WriteExcel (data / xlApp wBook cells i j)
  (setq
    xlApp (vlax-create-object "Excel.Application")
    wBook (vlax-invoke-method (vlax-get-property xlapp 'WorkBooks) 'Add)
    cells (vlax-get-property xlApp 'Cells)
    i 0
  (foreach row data
    (setq i (1+ i) j 0)
    (foreach val row
      (setq
        j (1+ j)
        cell (vlax-variant-value (vlax-get-property cells 'Item i j))
      (vlax-put-property cell 'Value2 val)
  (vlax-invoke-method
    (vlax-get-property
      (vlax-get-property xlApp 'ActiveSheet)
      'Columns
    'AutoFit
  (vlax-put-Property xlApp 'Visible :vlax-true)
(defun c:boxinfo ( / areaname js ent dxf_ent lst_pt data)
  (while (/= (setq areaname (getstring "\nArea name >")) "")
    (princ "\nSelect selection boundary")
    (while (null (setq js (ssget "_+.:E:S" '((0 . "LWPOLYLINE") (90 . 4)))))
      (princ "\nOject isn't valide")
    (setq
      ent (ssname js 0)
      dxf_ent (entget ent)
      lst_pt (mapcar '(lambda (x) (trans x ent 0)) (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) dxf_ent)))
      data (append  (mapcar '(lambda (x) (cons areaname x))(PolylineByLayer lst_pt)) data)
  (if data (WriteExcel (cons (list "Box name" "Layer" "Item" "Length") data)))
  (prin1)
Message 25 of 54
mss_selcukuni
I cant run this code... 😕
Message 26 of 54
CADaSchtroumpf
You have a full version of Autocad? or you use for exemple Briscad...?
If it is a full version, you can try before to run (vl-load-com) before (I forget it in the code)
Message 27 of 54
mss_selcukuni
Hi, Thank you so much,
1) Yes you are right.. My program is ZWCad..
We can run with ZW Cad?
2) we can draw shape which not such as rectangle.. Pls see attachments..
3) and last one, can we calculate area like @hak_vz 's code...
Can you help me?
Message 28 of 54
CADaSchtroumpf
I don't if this can get work in ZWCad, but you can try... (I doubt the function: (getpropertyvalue ....))
I not use Excel but write in CSV
(defun PolylineByLayer (l_pt / ss i pline layer len area lst sub)
        layer (cdr (assoc 8 (entget pline)))
        len (vlax-curve-getdistatparam pline (vlax-curve-getendparam pline))
        area (vlax-curve-getarea pline)
      (setq lst
          (subst (list layer (1+ (cadr sub)) (+ (caddr sub) len) (+ (cadddr sub) area)) sub lst)
          (cons (list layer 1 len area) lst)
(defun c:boxinfo ( / areaname js ent dxf_ent lst_pt data tmp f_open str_sep oldim)
    (while (null (setq js (ssget "_+.:E:S" '((0 . "LWPOLYLINE")))))
    (setq
      ent (ssname js 0)
  (setq
    tmp (vl-filename-mktemp "tmp.csv")
    f_open (open tmp "w")
    str_sep ";"
    oldim (getvar "dimzin")
  (setvar "dimzin" 0)
  (write-line
    (apply 'strcat (list "Box name" str_sep "Layer" str_sep "Item" str_sep "Length" str_sep "Area" str_sep))
    f_open
  (mapcar
    '(lambda (y)
      (write-line
        (apply 'strcat
          (mapcar
            '(lambda (x)
              (strcat
                (cond
                  ((eq (type x) 'STR) x)
                  ((eq (type x) 'INT) (itoa x))
                  ((eq (type x) 'REAL) (rtos x 2 2))
                  (T "")
                str_sep
            y
        f_open
    data
  (close f_open)
  (startapp "notepad" tmp)
  (setvar "dimzin" oldim)
  (prin1)
Message 29 of 54
mss_selcukuni
Can you add code which I want at @hak_vz' s code which is in his last post?
So can you edit his code?
Maybe it can run at zwcad
Message 30 of 54
mss_selcukuni
@CADaSchtroumpf
Yes, you are right..
This code isnt working..
this is error: bad function type - GETPROPERTYVALUE
But, @hak_vz 's code is working on ZWcad.. Can you edit this code?
Message 31 of 54
CADaSchtroumpf
@mss_selcukuni
I have edited my previous post for don't use GETPROPERTYVALUE in my code.
Try again with this modification.
Message 32 of 54
mss_selcukuni
Your lisp open notpad..
I want to open Excel... 😕
Message 33 of 54
mss_selcukuni
Just i want to added line layer name...
(and ı install autocad 🙂 )
Message 34 of 54
CADaSchtroumpf
Take the function from hak_vz and insert it at the beginning of the code.
(defun _openfile (file / sh)
  ;thanks to @ronjohnp
  (setq sh (vlax-get-or-create-object "Shell.Application"))
  (vlax-invoke-method sh 'open (findfile file))
  (vlax-release-object sh)
and at the end of the code just change:
by
(_openfile tmp)
You will be able to do that...?
Message 35 of 54
mss_selcukuni
sorry..
But its okey.. only can you add area value like lenght?
      (setq lst
  (setq
    i 0
  (foreach row data
    (setq i (1+ i) j 0)
    (foreach val row
      (setq
        j (1+ j)
  (vlax-invoke-method
    (vlax-get-property
      'Columns
    'AutoFit
    (setq
      ent (ssname js 0)
  (prin1)
Message 36 of 54
CADaSchtroumpf
What do you end up using? ZWCad or AutoCAD... 😩
With AutoCAD
      (setq lst
  (setq
    i 0
  (foreach row data
    (setq i (1+ i) j 0)
    (foreach val row
      (setq
        j (1+ j)
  (vlax-invoke-method
    (vlax-get-property
      'Columns
    'AutoFit
    (setq
      ent (ssname js 0)
  (if data (WriteExcel (cons (list "Box name" "Layer" "Item" "Length" "Area") data)))
  (prin1)
Message 37 of 54
mss_selcukuni
oh... well done.. Thank you sooo much @CADaSchtroumpf
I use Autocad finaly 🙂
Thanks thanks thanks so much.. 🙂
Message 38 of 54
mss_selcukuni
Can i ask 2 thing if it is not hard? 😕 😥
1)
When we "select" boundary box, can we select with "select box"?
Now we can select "select point"..
Can you please see attachment?
2)
can you add for circle and ellipse?
Message 39 of 54
CADaSchtroumpf
1)
2)
This?
(defun PolylineByLayer (l_pt / ss i pline ename layer len area lst sub)
  (if (setq ss (ssget "_WP" l_pt (append (list '(0 . "LWPOLYLINE,LINE,SPLINE,CIRCLE,ELLIPSE") (cons 410 (getvar "CTAB"))))))
      (setq
        ename (vlax-ename->vla-object pline)
      (if (member (vlax-get ename 'ObjectName) '("AcDbEllipse" "AcDbSpline"))
        (setq len (vlax-curve-getDistAtParam ename (vlax-curve-getEndParam ename)))
        (foreach typ_measure '("Length" "Circumference" "Perimeter")
          (if (vlax-property-available-p ename (read typ_measure))
            (setq len (vlax-get ename (read typ_measure)))
      (if (vlax-property-available-p ename "Area")
        (setq area (vlax-get ename 'Area))
        (setq area 0.0)
      (setq lst
  (setq
    i 0
  (foreach row data
    (setq i (1+ i) j 0)
    (foreach val row
      (setq
        j (1+ j)
  (vlax-invoke-method
    (vlax-get-property
      'Columns
    'AutoFit
    (while (/= (sslength (setq js (ssget  '((0 . "LWPOLYLINE"))))) 1)
      (princ "\nOject isn't valide or selection have too many objects")
    (setq
      ent (ssname js 0)
  (prin1)
Message 40 of 54
mss_selcukuni
Thank you so much @hak_vz   and @CADaSchtroumpf
This code is wonderful for uss...
