Lisp for T+G Boards (modifying existing lisp required)
paul9ZMBV
Message 1 of 11
paul9ZMBV
Hi
I have a lisp that someone was kind enough to do where it plots tounge and grooved boards
I could ideally do with it being modified slightly
I have attached a sample drawing as to what I want to achieve
Basically I need it to be able to ask if a bevel is required or not and whether a tongue is required on the ends or not
So I have the options to draw as per the options on the left hand side of the attached (I have the option currently to draw as per the right hand side)
I have attached the current lisp below
This would be much appreciated
Replies (10)
Message 2 of 11
paul9ZMBV
(defun c:t_g_board (/ total_width_dim _redraw total_width boards_number tongue_thickness tongue_setback tongue_length tongue_overlap insertion_point
              board_thickness boards_gap_chamfer one_board_width board_start_geom_list board_end_geom_list vertices_list
(setq total_width_dim (car (entsel "\nPick dimension for total width: "))
 _redraw (redraw total_width_dim 3)
 total_width (cdr (assoc 42 (entget total_width_dim)))
          boards_number (getint "\nEnter number of boards: ")
          board_thickness (getreal "\nEnter board_thickness: ")           ; 22
          tongue_thickness (getreal "\nEnter tongue thickness: ")   ;   6
          tongue_setback (getreal "\nEnter tongue setback: ")           ;   8
          tongue_length (getreal "\nEnter tongue_length: ")           ; 12
          boards_gap_chamfer (getreal "\nEnter boards_gap_chamfer: ")           ;   3
          insertion_point (getpoint "\nPick insertion point: ")
insertion_point_list '((0 0))
tongue_overlap (- tongue_length boards_gap_chamfer)
one_board_width (/ (- total_width (* boards_gap_chamfer (1- boards_number))) boards_number)
board_start_geom_list (list (list (list one_board_width (+ (- board_thickness) tongue_setback))   ; 1
    (list one_board_width (+ (- board_thickness) boards_gap_chamfer))       ;   2
    (list (- one_board_width boards_gap_chamfer) (- board_thickness))   ;   3
    (list boards_gap_chamfer (- board_thickness))                           ;       4
    (list 0 (+ (- board_thickness) boards_gap_chamfer))             ;   5
    (list 0 (+ (- board_thickness) tongue_setback))             ;   6
    (list (- tongue_length) (+ (- board_thickness) tongue_setback))     ;   7
    (list (- tongue_length) (+ (- board_thickness) tongue_setback tongue_thickness))    ;   8
    (list 0 (+ (- board_thickness) tongue_setback tongue_thickness))            ;   9
    (list 0 0)  ;   10
    (list one_board_width 0)    ;   11
    (list one_board_width (+ (- board_thickness) tongue_setback tongue_thickness))  ;   12
    (list (list (- one_board_width tongue_overlap) (+ (- board_thickness) tongue_setback tongue_thickness)) ;   1
    (list (- one_board_width tongue_overlap boards_gap_chamfer) (+ (- board_thickness) tongue_setback tongue_thickness))    ;   2
    (list (- one_board_width tongue_overlap boards_gap_chamfer) (+ (- board_thickness) tongue_setback)) ;   3
    (list (- one_board_width tongue_overlap) (+ (- board_thickness) tongue_setback))    ;   4
    board_end_geom_list (append (car board_start_geom_list)
    (list (list (+ one_board_width tongue_length) (+ (- board_thickness) tongue_setback tongue_thickness))) ;   13
    (list (list (+ one_board_width tongue_length) (+ (- board_thickness) tongue_setback)))  ;   14
(repeat (1- boards_number) (setq insertion_point_list (append insertion_point_list (list (mapcar '+ (last insertion_point_list) (list (+ one_board_width boards_gap_chamfer) 0))))))  (foreach insertion (vl-remove (last insertion_point_list) insertion_point_list)
(foreach pline board_start_geom_list
(vla-addlightweightpolyline (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
(vlax-safearray-fill (vlax-make-safearray vlax-vbdouble
(cons 1 (length (setq vertices_list
(apply 'append
(mapcar '(lambda (vertex) (mapcar '+ insertion_point insertion vertex))
pline
vertices_list
(vlax-put (vla-addlightweightpolyline (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
(apply 'append
vertex
board_end_geom_list
vertices_list
'closed
1
(redraw total_width_dim 4)
(princ)
Message 3 of 11
Sea-Haven
Have a look at this can be used as a front end when doing multiple value inputs, note returns string values but use atof etc to convet to real or atoi for integer.
Example code at top of code. Can be used in any code. Replaces this and can set default values.
(setq boards_number (atoi (nth 0 ans))  ; 8
    board_thickness (atof (nth 1 ans))  ; 22
    tongue_thickness (atof (nth 2 ans)) ; 6
    tongue_setback (atof (nth 3 ans))   ; 8
    tongue_length (atof (nth 4 ans))    ; 12
    boards_gap_chamfer (atof (nth 5 ans))  ; 3
Message 4 of 11
paul9ZMBV
This sounds amazing it would good if someone would be so kind as to incorporate this into this into a complete working lisp, im quite new to this and this is beyond my skills currently.
Message 5 of 11
Sea-Haven
Ok part 2. I posted already what to do once you fill in values. Have a go at using it.
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(setq ans (AH:getvalsm (list "Enter values"
  "Enter number of boards: "  5 4 "10"
  "Enter board_thickness: " 5 4 "22"
  "Enter tongue thickness: " 5 4 "6"
  "Enter tongue setback: " 5 4 "8"
  "Enter tongue_length: " 5 4 "12"
  "Enter boards_gap_chamfer: " 5 4 "3"
Message 6 of 11
paul9ZMBV
sorry a little confused could this be added to the lisp below please so its a complete working lisp
but i like the look of it a lot
(defun c:t_g_board (total_width_dim _redraw total_width boards_number tongue_thickness tongue_setback tongue_length tongue_overlap insertion_point
tongue_overlap (tongue_length boards_gap_chamfer)
one_board_width ((total_width (boards_gap_chamfer (1- boards_number))) boards_number)
board_start_geom_list (list (list (list one_board_width ((board_thickness) tongue_setback))   ; 1
    (list one_board_width ((board_thickness) boards_gap_chamfer))       ;   2
    (list (one_board_width boards_gap_chamfer) (board_thickness))   ;   3
    (list boards_gap_chamfer (board_thickness))                           ;       4
    (list 0 ((board_thickness) boards_gap_chamfer))             ;   5
    (list 0 ((board_thickness) tongue_setback))             ;   6
    (list (tongue_length) ((board_thickness) tongue_setback))     ;   7
    (list (tongue_length) ((board_thickness) tongue_setback tongue_thickness))    ;   8
    (list 0 ((board_thickness) tongue_setback tongue_thickness))            ;   9
    (list 0 0)  ;   10
    (list one_board_width ((board_thickness) tongue_setback tongue_thickness))  ;   12
    (list (list (one_board_width tongue_overlap) ((board_thickness) tongue_setback tongue_thickness)) ;   1
    (list (one_board_width tongue_overlap boards_gap_chamfer) ((board_thickness) tongue_setback tongue_thickness))    ;   2
    (list (one_board_width tongue_overlap boards_gap_chamfer) ((board_thickness) tongue_setback)) ;   3
    (list (one_board_width tongue_overlap) ((board_thickness) tongue_setback))    ;   4
    (list (list (one_board_width tongue_length) ((board_thickness) tongue_setback tongue_thickness))) ;   13
    (list (list (one_board_width tongue_length) ((board_thickness) tongue_setback)))  ;   14
(repeat (1- boards_number) (setq insertion_point_list (append insertion_point_list (list (mapcar '+ (last insertion_point_list) (list (one_board_width boards_gap_chamfer) 0))))))  (foreach insertion (vl-remove (last insertion_point_list) insertion_point_list)
(apply 'append
pline
vertices_list
(apply 'append
vertex
board_end_geom_list
vertices_list
'closed
1
(princ)
Message 7 of 11
Sea-Haven
Your lucky in a good mood and had time. Look at how code is used for future programs with lots of value entries. The Multi getvals.lsp needs to be saved in a support path or edit the (load "c:\\yourdirectorypath\\Multi getvals.lsp")
(setq insertion_point (getpoint "\nPick insertion point: ")
    (list 0 0)  ;   10
(apply 'append
pline
vertices_list
(apply 'append
vertex
board_end_geom_list
vertices_list
'closed
1
(princ)
(c:t_g_board)
Pretty cool answer
Message 8 of 11
paul9ZMBV
Hi Sea-Haven
Thanks so much for that its very much appreciated and works seamlessly
The only thing that i need changed to make it perfect is that if i don't want a bevel it doesn't work ie i enter 0 value for the bevel
In an ideal world i could do with a separate input for the bevel and a separate input for the gap between (and if the bevel input was 0 it would just draw as square edged rather than a bevel)
I fully understand if you don't have the time for this
What you have done is greatly appreciated.
Message 9 of 11
paul9ZMBV
i have managed to add the gap input and chamfer input separately and set variables, (board_gap and board_chamfer)
I just need help making the t+g boards draw with the separate variables
for example if the board_chamfer is 0 it draws the t+g boards with square edges
  "Enter boards_gap: " 5 4 "3"
  "Enter board_chamfer: " 5 4 "3"
    boards_gap (atof (nth 5 ans))
    board_chamfer (atof (nth 6 ans))
    (list 0 0)  ;   10
(apply 'append
pline
vertices_list
(apply 'append
vertex
board_end_geom_list
vertices_list
'closed
1
(princ)
(c:t_g_board)
Message 10 of 11
komondormrex
@paul9ZMBV
someone, eh) you've gotta be kidding)
@Sea-Haven
Alan, nothing personal, but for me you really act like a certain sausage seller with this multi... of yours)
Message 11 of 11
paul9ZMBV
thanks @komondormex
No offence intended I couldn't remember who done the t+g lisp originally
The lisp you show in the video is perfect any chance of the coding please, it would be very much appreciated
