LISP for printing from a button
tims79
Message 1 of 16
tims79
I'm having a problem with a LISP routine for printing to a pdf file.  I have the LISP working as desired - but only if I type the command into the command prompt.  What I would like to do is run the command from a button on the ribbon.  But when I do that, the LISP gets hung up on the step where it saves the file to a folder.  Can anyone tell me what am I doing wrong?  I don't understand why the same command works differently when entered command line vs. button.  Attached is my lisp file.
Replies (15)
Message 2 of 16
Jonathan3891
See if this works.
(defun c:PDFLIMITS1=1MM (/ dwg)
	(command "tilemode" "1")
	(command "cmdecho" "1")
	(command "-plot"
	"y"; detailed configuation
	"MODEL"; layout name
	"Autocad PDF (Smallest File).pc3"; device name
	"ANSI full bleed A (11.00 x 8.50 Inches)"; paper size
	"M"; paper units
	"L"; orientation
	"N"; plot upside down?
	"L"; plot area - Limits
	"1=1"; scale
	"CENTER"; Offset
	"N"; plot with styles?
	"."; style table name
	"Y"; plot with lineweights?
	"A"; shade plot setting
	(strcat "C:\\temp\\"(getvar 'dwgprefix) (substr (setq dwg  (getvar 'dwgname)) 1 (- (strlen dwg) 4)) ".pdf")
	"y"
	"Y"
  	(princ)
Jonathan Norton
Blog | Linkedin
Message 3 of 16
tims79
Not quite.  I think that is adding the current drawing prefix, when I was already specifying C:\Temp\.  If I remove the  (getvar 'dwgprefix)  I am right back where I started.  It works from the command line but not from a button.
Message 4 of 16
Jonathan3891
OK, that was untested.
I've tested this and it works with a button.
(defun c:ttt (/ )
	(command "-plot"
	"M"; paper units
	"L"; orientation
	"1=1"; scale
	"CENTER"; Offset
	(strcat "C:\\temp\\" (substr (getvar 'dwgname) 1 (- (strlen (getvar 'dwgname)) 4)) ".pdf")
	"y"
	"Y"
  	(princ)
Jonathan Norton
Blog | Linkedin
Message 5 of 16
SeeMSixty7
I think your problem is the name of your command. take the equals (=) sign out of your defun statement.
Hope that helps
Message 6 of 16
tims79
When you assigned a button to run it, for the button did you just enter ttt for the macro?  That isn't working for me, but it does work to enter ttt in the command line.
Message 7 of 16
Jonathan3891
The button command is
^C^Cttt
Jonathan Norton
Blog | Linkedin
Message 8 of 16
tims79
This is what has been driving me crazy.  I get the same hanging result with ^C^Cttt.  Attached is a screencap of my Autocad text window when running it from a button.  It looks like something goes wrong when saving the pdf.
Which version of Autocad are you using?  I have 2019
Message 9 of 16
Scottu2
I loaded your Lisp and added a macro to my toolbar.
It works for me, even with the =. (Autocad 2019)
The filename does not match,  the command string is off by one line.
Perhaps the plot string keystrokes where created while in paper space?
If the menu macro is using lisp commands to load the lisp first then check that code again.
Message 10 of 16
Sea-Haven
Message 11 of 16
tims79
The arrow you made pointing to the filename not matching - that is the problem. Something is going wrong at that point - but ONLY when I run the command from a button macro. If I type the command in it works perfectly.
The macro is simply the same command as I am typing manually, not loading a lisp first. The lisp is already loaded, verified by the fact that it works manually.
Is there some setting related to macros and the writing of files/directories? Security or permission setting? I am at a loss.
Message 12 of 16
tims79
Is there some setting related to macros and the writing of files/directories? Security or permission setting? I am totally at a loss.
Message 13 of 16
Scottu2
Hi Tim79,
When it did my test is was using the tool bar, it see that the ribbon is used here.
Compare the plot command results. See attached screen shot.
Message 14 of 16
tims79
Scott
Obviously, I noticed the different results.  That is what I don't understand and my whole reason for posting here.
You seem to be onto something with the toolbar vs ribbon, though.  It works correctly when launched from a toolbar button.  So it looks like the problem is with the ribbon interface.  That is good enough for me, I will just make a toolbar with the buttons I need.  Screw the ribbon!
Message 15 of 16
Scottu2
Hello tims79,
Good you got it working.  As for the ribbon, the symptom is similar to plotting from LAYOUT vs MODEL space.  The layout adds questions regarding to paper space.
Perhaps you can still use the ribbon, by setting a variable to 1 to indicate the routine is to use a different plot command string and the routine sets that variable back to zero.
Message 16 of 16
Scottu2
Hi Tims79,
I  made the ribbon button and ran the routine and it works, on my machine.
I was not able to reproduce the error, so the original code is good.
Attached is the ribbon button AP i created.
