Lisp for Numbering overlapping lines.
arpansark0544TCX
Message 1 of 17
arpansark0544TCX
I am working on electrical conducting.
I used a line to connect the circuits. As as a result there are multiple overlapping line.
Is there a Lisp which could place a number near the overlapping line showing number of line operlapping.
Or a little advance if it can replace those lines with a numbered line type.
I am attaching a image for better understanding:
Option 1:
Advance option2:
Replies (16)
Message 2 of 17
hak_vz
@arpansark0544TCX  Attach sample drawing and in same drawing add numbered lines.  Always attach sample drawing with your requests.
Miljenko Hatlak
Message 3 of 17
arpansark0544TCX
Sir as requested by you I have attached the drawing file and my .lin file for numbered line type.
Message 4 of 17
hak_vz
I'll work on it later today.
Miljenko Hatlak
Message 5 of 17
arpansark0544TCX
Thank you for your support.
Mean while i am working on it manually 😅.
too complex:
Message 6 of 17
hak_vz
@arpansark0544TCX
Here you have starting version that counts line overlaps and create text over overlapped lines. I will later today modify it to remove duplicates and replace line type of remaining line.
(defun c:pow_line_overlap ( / duplicates ss e ent i ptlist p)
	(defun duplicates ( lst )
		(if lst
			(if (member (car lst) (cdr lst))
				(cons (car lst) (duplicates (vl-remove (car lst) (cdr lst))))
	(setq ss (ssget "X" '((0 . "LINE")(8 . "EE-R PHASE"))) i -1 ptlist nil)
	(while (< (setq i (1+ i)) (sslength ss))
		(setq
			e (ssname ss i)
			ent (entget e)
			p (mapcar '* '(0.5 0.5)(mapcar '+ (cdr (assoc 10 ent))(cdr (assoc 11 ent))))
			ptlist (cons p ptlist)
	(setq dup (duplicates ptlist))
	(foreach pt dup
		(setq ss (ssget "_C" (mapcar '+ '(1 1) pt) (mapcar '+ '(-1 -1) pt) '((0 . "LINE"))))
			(entmake
				(list
					(cons 0 "text")
					(cons 8 "EE-POWER CIRCUIT")
					(cons 10 pt)
					(cons 40 150)
					(cons 50 0)
					(cons 1 (itoa (sslength ss)))
	(princ "\nDone!")
	(princ)
Miljenko Hatlak
Message 7 of 17
arpansark0544TCX
It is working like a wonder.
Thank you.
Can't wait to see the advance option.
Message 8 of 17
hak_vz
I will assume that linetypes are named "C1" "C2"......."C49"  according to your acad.lin.  To work correctly all power lines  must be placed in layer named "EE-R PHASE" . If this name changes depending on project, then I can change line selection so that you can pick a line on desired layer.
Miljenko Hatlak
Message 9 of 17
arpansark0544TCX
I have the following observation:
The code should be able to ask the user to select the bunch of lines to work on. So it can be user-friendly to other Cad users also.
This is what I think. However, I am still a beginner in Lisp coding .So don't know the practicality it is possible.
Message 10 of 17
hak_vz
Final edited version that will work in case of minor drafting errors as found in sample drawing
(defun c:pow_line_overlap ( / *error* duplicates ss e ent i ptlist p ovl old_expert dup)
;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-for-numbering-overlapping-lines/td-p/12478216
;author: hak-vz
;https://forums.autodesk.com/t5/user/viewprofilepage/user-id/5530556
; 05. january 2024.
	(defun *error* ( msg )
		(if (not (member msg '("Function cancelled" "quit / exit abort")))
			(princ)
		(setvar 'cmdecho 1)
		(setvar 'expert old_expert)
		(vla-endundomark adoc)
		(princ)
		(if lst
	(setq adoc (vla-get-ActiveDocument (vlax-get-acad-object)))
	(vla-startundomark adoc)
	(setq old_expert (getvar 'expert))
	(setq ss (ssget "X" '((0 . "LINE")(8 . "EE-R PHASE"))) i -1)
	(setvar 'cmdecho 0)
		(setq
			ent (entget (ssname ss i))
			a (cdr (assoc 10 ent))
			b (cdr (assoc 11 ent))
			ptlist (cons (mapcar 'fix (mapcar '* '(0.5 0.5)(mapcar '+ a b))) ptlist)
	(foreach pt (duplicates ptlist)
		(setq ss (ssget "_C" (mapcar '+ '(15 15) pt) (mapcar '+ '(-15 -15) pt) '((0 . "LINE"))))
		(setq i 0 ovl (sslength ss))
			(entdel (ssname ss i))
		(setq e (ssname ss 0))
		(command "_.linetype" "load" (strcat "C" (itoa ovl)) "acad.lin" "")
		(command "_.chprop" e "" "LTYPE" (strcat "C" (itoa ovl)) "")
		(command "_.chprop" e "" "LTSCALE" 55 "")
		(setq ent (entget e))
		(setq ent (subst (cons 8 "EE-POWER CIRCUIT")(assoc 8 ent) ent))
		(setq ent (entmod ent))
	(setvar 'cmdecho 0)
	(princ "\nDone!")
	(princ)
Miljenko Hatlak
Message 11 of 17
arpansark0544TCX
I tested it out and it looks amazing.
Few observation :
Some lines are not changed which are overlapped as the code version 2.0  was not able to change them.
But in Version 1.0 the code placed a number there.
Message 12 of 17
ВeekeeCZ
(defun c:Multilining ( / :ltload s i d n m l a)
  (defun :ltload (lt)
    (if (or (tblsearch "ltype" lt)
	    (command "_.linetype" "_l" lt "acad" "")
	    (tblsearch "ltype" lt))
      lt
      "Continuous"))
  (if (setq s (ssget '((0 . "LINE"))))
    (repeat (setq i (sslength s))
      (setq d (entget (ssname s (setq i (1- i))))
	    n (list (cdr (assoc 10 d)) (cdr (assoc 11 d)))
	    m (mapcar '/ (apply 'mapcar (cons '+ n)) '(2 2))
	    a t
	    l (mapcar (function (lambda (x) (if (equal m (last x) 1e-2)
				     (progn
				       (setq a nil)
				       (cons (1+ (car x)) (cdr x)))
				     x)))
		      l)
	    l (if a (cons (list 1 n m) l) l))))
  (foreach e l (entmake (list '(0 . "LINE")
			      (cons 8 (getvar 'clayer))
			      (cons 6 (:ltload (strcat "C" (itoa (car e)))))
			      (cons 10 (caadr e)) (cons 11 (cadadr e)))))
  (command "_.erase" s "")
  (princ)
Message 13 of 17
hak_vz
@ВeekeeCZ  Great code as always. What it hast to be considered is that overlapping lines may also have different direction,  as in OP case. For this reason to simplify code I use line middle-point.
Miljenko Hatlak
Message 14 of 17
hak_vz
@arpansark0544TCX  Compare both versions of the code on some sample and test if they create equal result. I think that maybe I made a mistake with iterators in second version, since I didn't use your line types from "acad.lin"
Miljenko Hatlak
Message 15 of 17
ВeekeeCZ
Right, thanks. It seemed to me that it was all in the same direction. Well, it's mostly.
But the precision also isn't so perfect. Needed to lower the fuzz down to 1e-2
Message 16 of 17
hak_vz
@arpansark0544TCX  Code in post #10 is edited so it now works in case of minor drafting error as is shown in your post #11. If you make large zoom you can see that lines are drafted with error.
Miljenko Hatlak
Message 17 of 17
arpansark0544TCX
Thank you it worked charm this time.
