Thank you, now I can have the content of the data object table in a csv file.
I have a few questions :
1) when I select the polylines of a whole apartment with your LISP, I am unable to choose some of them.
Namely for the upper toilets and the cupboards, they do not get selected even if I try to select them.
When not using the LISP, I can select them with no problem.
Do you know why ?
2) In the csv file I get the room names (I added a "room name" field in the table) and their features in a descending order, beginning with Building 9, Floor 9, Apartment 99 for exemple, and ending with Building 1, Floor 1, Apartment 1. What should I change in the code in order to have them in an ascending order ?
3) In the csv file, on rare occasions, there's a break in the order : for example, I have 8 rooms for apartment 32 listed, then all the rooms for apartment 31, then the 2 remaining rooms of apartment 32.
Do you know the reason ?
Again, thank you very much.
(Sorry, i replied to the wrong person in the first place)
Edit : I added 2 photos to show you the problem. When I am asked whether I want to do a manual selection or not, when I choose "all", they are not all present in the csv file, and when I choose "manual" and pick the polylines I need, some (always the same) are not taken into account. It's always one toilet room and two cupboards. That happens when I have to click on a polyline and then chose manual and pick the rest of the polylines.
If the first one I pick is not among the 3 problematic ones, they will not be selected after when I pick the whole apartment, and when the first polyline I pick is among the problematic ones, only these 3 polylines are selected when I try to select a whole apartment.
I'm using Map 3D 2023, that's maybe part of the problem ?
