Lisp for dynamic block - rotate action
yu85.info
yu85.info
Hi, I have this DWG attached .I need to make this drawing a block that some objects can be rotated (from A to B). This is just an example the actual drawing is more complex.
Is there a way to create a lisp routine so at first I will choose the elements i need to be with a rotate parameter and then the entire drawing and the result B will come up?
Thanks you very much for your help
Replies (23)
Moshe-A
@yu85.info ,
We could take all objects from the model space and assign only the yellows for the dynamic rotate (are you aware that we are talking only on objects that are set yellow by Object and not from yellow Layer)
is there any change that a yellow objects will exist in model space that are not to be assigned to dynamic rotate?
Moshe
yu85.info
- We could take all objects from the model space and assign only the yellows for the dynamic rotate -
Good... but...
- are you aware that we are talking only on objects that are set yellow by Object and not from yellow Layer -
The yellow color was just for the example so I can explain that I need just some of the objects and not all. actually I need the lisp to work on any objects selected regardless their color to layer.
The ideal way is to take all the objects from the model space and assign only the selected objects for the dynamic rotate.
Moshe-A
@yu85.info  shalom,
tell you the truth, i am not really understand what is your goal.
and why the 'hetz zaphone' is needed, this not mapa 😀
anyway i think this is solved
enjoy
Moshe
(defun c:WrapDynBlk (/ getBlockName ; local function
		       bname r0 ss0 ss1 bname)
 (defun getBlockName (/ flag name)
  (while (not flag)
   (setq name (getstring t "\nBlock name: "))
   (cond
    ((eq name "")
     (setq flag t)
      name
    ); case
    ((tblsearch "block" name)
     (princ (strcat "\nBlock \"" name "\" is already exist."))
    ); case
    ( t
     (setq flag t)
    ); case
   ); cond
  ); while
  name
 ); getBlockName
 ; here start c:WrapDynBlk
 (setvar "cmdecho" 0)
 (command "._undo" "_begin")
 (if (and
       (/= (setq bname (getBlockName)) "")
       (setq r0 (getpoint "\nRotation base point: "))
       (setq ss0 (ssget))
  (progn
   (command "._copybase" "0,0" "_si" ss0)
   (command "._erase" "_si" ss0)
   (command "._block" bname "0,0" "_si" "_all")
   (command "._bedit" bname)
   (setq ename (entlast))
   (command "._pasteclip" "0,0")
   (setq ss1 (ssadd))
   (while (setq ename (entnext ename))
    (ssadd ename ss1)
   ); while
   (command "._bparameter" "_rotation" r0 0.5 "" "" "")
   (command "._bactiontool" "_rotate" (polar r0 (/ pi 4) 0.5)"_si" ss1)
   (command "._bclose" "_save")
   (command "._insert" bname "0,0" 1 1 0)
  ); progn
 ); if
 (command "._undo" "_end")
 (setvar "cmdecho" 1)
 (princ "\nDone.")
 (princ)
); c:WrapDynBlk
yu85.info
OMG! hallelujah!
TODA RABA
Works wonderfully
