lisp for Drawing elbow for fastest
smallƑish
Message 1 of 27
smallƑish
I'm using "RD" lisp to draw all kinds of reducers written by @komondormrex , The fastest program ever (actions 1 & 2 in GIF). Can anyone help me to do the same for my elbow? GIF, Lisp, and DWG are attached for more clarity.
Note : All objects are lines. ( No polyline)
Replies (26)
Message 2 of 27
ronjonp
Fillet using radius 0 then join and use the code I've already given you.
Message 3 of 27
smallƑish
Dear @ronjonp
The given code is not working with lines;
As all my drawings are lines (not polylines)
Also, the lisp only works with the polylines which are already fillet and joined
Multiple elbows in a single polyline give the wrong results.
hence it's making it more complicated than normal (gif attached)
Message 4 of 27
ronjonp
@smallƑish
For what you're trying to accomplish, can't you trial software? @_Tharwat Has written a duct suite. Might save you some headaches.
Message 5 of 27
_Tharwat
Thank you @ronjonp for your recommendation.
Here are my entire HVAC programs.
https://autolispprograms.wordpress.com/hvac/
Message 6 of 27
smallƑish
Please have a look. your code does not give accurate results gif is attached.
Message 7 of 27
smallƑish
Thank you for your reply. I have tried this. But it's more advanced tools than my current work style. I wish to continue with the conventional method.
Message 8 of 27
diagodose2009
Please  I downloaded, but in my computer not exists .
Inside AutoCad do not found the program  "HVACTharwat Al Shoufi".
How to start-up he?
Message 9 of 27
smallƑish
Type HVAC as CMD, You will gate a new pop up window in that you have to choose what you want to draw either duct, elbow taper etc it's very good and really advanced drafting application
See here https://youtu.be/9f3HRUpfaGA?feature=shared
Message 10 of 27
ronjonp
Yup .. all it looks for is areas of the polylines to determine which is "inside" .. this can easily be fooled by a scenario like this:
Message 11 of 27
Sea-Haven
Maybe pick 2 points ? the 1st is always inside. Another I have used is drag line over 1st 2 lines then over other 2 lines. This implies 2nd point is the inside. Think "L". I have this for multi fillet many lines at a time.
Message 12 of 27
smallƑish
Think it's an impossible task. 😐
Message 13 of 27
Sea-Haven
Yes it is possible just need code to suit.
Message 14 of 27
smallƑish
Glad to know that it's possible, but I m not that brilliant to understand the idea here. Also I m just started learning lisp. Hence no clue, what I needed to do here.
Message 15 of 27
Sea-Haven
Good time to learn, start with pt1 (getpoint ........ pt2 (getpoint pt1 ........ pt3 (getpoint pt2 .....
(ssget "F" (list pt1 pt2 pt3)......
Ok next step is line 1 closer to pt1 or line 2 ? Need to use (setq intpt1 (vlax-invoke obj2 'intersectWith obj1 acExtendThisEntity)) twice and compare (distance ptx intpt1) this forces the order of your line work to be in a pattern. Outside inside inside outside. Then fillet is outsidept1 outsidept2, insidept1 insidept2.
Now in your other post and did comment dont double post, you can also get the width between the lines.
Its all common code used so many times.
if you google "fillet multiple lines Autocad lisp" should find one all done. But have a go only way to learn.
Message 16 of 27
smallƑish
Message 17 of 27
ronjonp
@smallƑish Wouldn't it be easier to use centerlines?
Message 18 of 27
Sea-Haven
Agree with you Ronjonp I posted some code recently that allows you to offset a pline segment with different offsets so a duct program could have different widths. This is sounding again like Tharwat HVAC program.
Message 19 of 27
smallƑish
how can we get the lisp file for this?
Message 20 of 27
ronjonp
@smallƑish
This was given to you already a couple of weeks ago HERE.
