- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear community,
I have two separate LISPs for optional setting of the text position in the selected dimension, without the person having to change these values in the properties of the dimension each time.
The first LISP changes the value of the system variable DIMGAP (text gap) between 1.5 or 5.5. The second LISP changes the value of the system variable DIMTAD (vertical text position) between above or below.
The initial value of the text position in the dimension is DIMTAD = above, DIMGAP = 1.5.
Please, it is possible to somehow combine these two LISPs so that the position of the text in the selected dimension changes in "this order":
1) DIMTAD = above, DIMGAP = 5.5
2) DIMTAD = under, DIMGAP = 1.5
2) DIMTAD = above, DIMGAP = 5.5
2) DIMTAD = above, DIMGAP = 1.5
The sample data and the two LISPS see attachment.
Thank you in advance for your help and have a nice day.
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
