LISP for DimAli Dimensions
PLM1987
PLM1987
Hey everyone!
I have in my drawing a 10km long alignment with two auto feature lines that are derived from a corridor that also follows the full length of my alignment.
Currently, I have to manually go through and place every aligned dimension for the distance between my alignment and this feature line.
I'm wondering if there is some way to automate this? (I have 18 of these models). Essentially, I am looking for a LISP, or some other solution to automatically place a DimAli say.... every 100m on the alignment that originates at the alignment and snaps perpendicular to the alignment to the corresponding feature line on both sides (2 Dimensions every 100m, 1 on each side of the alignment)
Any help would be appreciated thank you!
ВeekeeCZ
I have a routine that does this for PL vs PL (lw). If you insist on AL vs FL, you need to post it to C3D cust forums.
PLM1987
This worked exactly as intended thank you very much!
Sea-Haven
Known as Peg and Shift its in CIVIL SITE DESIGN as an option. Uses alignments etc.
