I don't known if I have good understand, but you can try this, don't use "Enter" for options, use simply key.
Generating muliple size of A4 dimension with selection scale (+/-), move cursor at screen for draw the box.
(defun des_vec (lst col / lst_sg)
(setq lst_sg (list (cadr lst) (car lst)))
(setq lst (cdr lst))
(while lst
(if (cadr lst)
(setq lst_sg (cons (cadr lst) (cons (car lst) lst_sg)))
(setq lst_sg (cons (last lst_sg) (cons (car lst) lst_sg)))
(setq lst_sg (cons col lst_sg))
(grvecs lst_sg)
(defun c:A4_dyn ( / unit_draw hview old_snapang pt_ins dx dy pt_tmp ang l_scale format_scale coeff key pt_key n nb_column nb_raw pt_row count s_ang)
(if (or (eq (getvar "USERS5") "") (not (eq (substr (getvar "USERS5") 1 2) "qz")))
(progn
(initget "KM ME CM MM")
(if (not(setq unit_draw (getkword "\nDessin réalisé en [KM/ME/CM/MM] <ME>: ")))
(setq unit_draw "ME")
(cond
((eq unit_draw "KM")
(setq unit_draw 1000000)
((eq unit_draw "ME")
(setq unit_draw 1000)
((eq unit_draw "CM")
(setq unit_draw 10)
((eq unit_draw "MM")
(setq unit_draw 1)
(setvar "USERS5" (strcat "qz" (itoa unit_draw)))
(setq unit_draw (atoi (substr (getvar "USERS5") 3)))
(setq
hview (getvar "VIEWSIZE")
old_snapang (getvar "SNAPANG")
pt_ins (list (- (car (getvar "VIEWCTR")) (* hview 0.5)) (- (cadr (getvar "VIEWCTR")) (* hview 0.5)))
dx 210.0 dy (* 210.0 (sqrt 2)) pt_tmp pt_ins ang (getvar "SNAPANG")
l_scale '(1.0 1.25 2.0 2.5 5.0 7.5)
format_scale (car l_scale)
coeff 1.0
(if (> (fix (/ hview dy)) 3)
(while (> (fix (/ hview dy)) 3)
(foreach value l_scale
(setq format_scale value dx (* 210.0 format_scale) dy (* 210.0 (sqrt 2) format_scale))
(setq
coeff (* coeff 10.0)
l_scale (mapcar '(lambda (x) (* x coeff)) l_scale)
(if (< (fix (/ hview dy)) 1)
(while (< (fix (/ hview dy)) 1)
(foreach value (reverse l_scale)
(setq
coeff (* coeff 0.1)
format_scale (last l_scale)
;(print format_scale)
(princ (strcat "\nSpécifiez le coin haut droit ou [R] pour effectuer une rotation, [D] un déplacement, [+/-] un changement d'échelle <" (rtos (* unit_draw format_scale) 2 3) ">: "))
(while (and (setq key (grread T 4 0)) (/= (car key) 3))
(cond
((eq (car key) 5)
(setq pt_key (cadr key))
(setq n
(setq nb_column (fix (/ (+ (* (- (car pt_key) (car pt_ins)) (cos ang)) (* (- (cadr pt_key) (cadr pt_ins)) (sin ang))) dx)))
(setq nb_raw (fix (/ (- (* (- (cadr pt_key) (cadr pt_ins)) (cos ang)) (* (- (car pt_key) (car pt_ins)) (sin ang))) dy)))
pt_row pt_ins count 0
(redraw)
(repeat n
(des_vec
(list
(list (car pt_ins) (cadr pt_ins))
(list (+ (car pt_ins) (* dx (cos ang))) (+ (cadr pt_ins) (* dx (sin ang))))
(setvar "LASTPOINT"
(list
(+ (car pt_ins) (- (* dx (cos ang)) (* dy (sin ang))))
(+ (cadr pt_ins) (+ (* dy (cos ang)) (* dx (sin ang))))
(list (- (car pt_ins) (* dy (sin ang))) (+ (cadr pt_ins) (* dy (cos ang))))
3
(setq count (1+ count))
(if (< count nb_column)
(setq pt_ins (list (+ (car pt_ins) (* dx (cos ang))) (+ (cadr pt_ins) (* dx (sin ang)))))
(setq pt_ins (list (- (car pt_row) (* dy (sin ang))) (+ (cadr pt_row) (* dy (cos ang)))) pt_row pt_ins count 0)
(setq pt_ins pt_tmp)
((or (eq (cadr key) 114) (eq (cadr key) 82))
(initget 0)
(setq s_ang
(getorient pt_ins
(strcat
"\nNouvel angle<"
(angtos (getvar "SNAPANG"))
(if (not s_ang) (setq s_ang ang))
(if (and (> s_ang (/ pi 2)) (<= s_ang (/ (* 3 pi) 2)))
(setq ang (+ s_ang pi))
(setq ang s_ang)
(setvar "SNAPANG" ang)
((or (eq (cadr key) 100) (eq (cadr key) 68))
(initget 9)
(setq pt_ins (getpoint "\nSpécifiez le coin bas gauche: "))
(setq pt_ins (list (car pt_ins) (cadr pt_ins)) pt_tmp pt_ins)
((eq (cadr key) 43)
(setq format_scale (cadr (member format_scale l_scale)))
(if (not format_scale) (setq format_scale (car (setq l_scale (mapcar '(lambda (x) (* x 10.0)) l_scale)))))
(setq dx (* 210.0 format_scale) dy (* 210.0 (sqrt 2) format_scale))
((eq (cadr key) 45)
(setq format_scale (cadr (member format_scale (reverse l_scale))))
(if (not format_scale) (setq format_scale (last (setq l_scale (mapcar '(lambda (x) (* x 0.1)) l_scale)))))
(princ "\n")
(redraw)
(princ (setq toto (list (list pt_ins (getvar "LASTPOINT")) (getvar "SNAPANG") (* unit_draw format_scale))))
(command "_.rectang" "_none" (caar toto) "_rotation" (angtos (getvar "SNAPANG")) "_none" (cadar toto))
(setvar "SNAPANG" old_snapang)
(prin1)
