Lisp for combining multiple block attributes into a main block
timothy.birdwell
Message 1 of 27
timothy.birdwell
                I am looking for a lisp either already created or help with creating. What it needs to do is gather data from other blocks and incorporate that data into one block. In this situation my main block would be Fiber_Ped, I need to incorporate the data from the other blocks into it. A test drawing will be supplied. All I need from the second block is the assignment number and the address.
368
916 WACO OAKDALE LA 71463
369
370
371
372
403
                So essentially the Lisp would need create a new attribute system, that can house the information stored from the other blocks up to 12 assignment numbers.
Replies (26)
Message 2 of 27
Sea-Haven
Try this select the attribute text to get its name eg 368, then window select all the blocks, pick a point for new block and angle.
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-for-combining-multiple-block-attributes-into-a-main-block/td-p/11637019
(defun c:wow ( / )
(setq ent (nentsel "Pick block attribute for name "))
(setq attname (cdr (assoc 2 (entget (car ent)))))
(prompt "\nSelect the blocks ")
(setq ss (ssget '((0 . "INSERT"))))
(if (= ss nil)
(alert "No blocks picked will exit")
(progn
  (setq lst '())
  (repeat (setq x (sslength ss))
    (setq blk (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
              (setq atts (vlax-invoke blk 'Getattributes))
          (if (= atts nil)
		  (princ)
		  (foreach att atts
	        (if (= (vla-get-tagstring att) attname)
             (setq lst (cons (vla-get-textstring att) lst))
(setq lst (reverse (vl-sort lst '<)))
(setq len (- 11 (length lst)))
(repeat len
  (setq lst (cons "" lst))
(setq lst (reverse lst))
(setq pt (getpoint "\npick point for block ") ang (getreal "\nEnter angle "))
(if (= ang nil)(setq ang 0.0))
(setq x -1)
(setvar 'attreq 0)
(command "-insert" "Fiber_Ped" pt 1.0 1.0 ang)
(setq atts (vlax-invoke (vlax-ename->vla-object (entlast) ) 'getattributes))
(setq x -1)
(repeat (length lst)
  (vla-put-textstring  (nth (setq x (1+ x)) atts)   (nth x lst))
(setvar 'attreq 1)
) ; ss nil
(princ)
(c:wow)
Message 3 of 27
timothy.birdwell
So with this code, when I select the subscriber block, which would be the number. Then I select the fiber ped box and press enter, I select the point and angle. A new block is inserted but with the standard ped_block information with nothing filled out.
Message 4 of 27
timothy.birdwell
So what I am needing is to be able to extract information from block "SUBSCRIBER", ASSIGNMENT_NUM " x". Also from this block I need to extract information from OD:SUBSCRIBER, lines 5, 7, 8, 11, 12, 10. These lines will be combined together to make the address as one line. This info needs to be placed on the block Fiber_Ped. Now if the lisp creates a new OD on top of the Fiber_Ped is acceptable. Also if can get the numbers to go in descending order. I can almost see how to write it but don't know how to start writing it.
Message 5 of 27
Sea-Haven
Adding OD data adds a lot more complexity, but the simple answer is to use a LIST make the list with the number as 1st item then add all your OD data to list, so when you use the vl sort function its based on the number.
((368 "916 WACO OAKDALE LA 71463")(402 "123 WACO WOOD ST LA 71463)(.....))
Message 6 of 27
timothy.birdwell
Wanting to make sure im on the right track so far what I have is a function that pulls the variables and stores into a temporary list.
(defun c:extract (/)
  ((setq SubscriberBlock (entsel))
   (setq SubscriberBlockList (entget (car SubscriberBlock)))
   (if (/= (cdr (assoc 0 SubscriberBlockList)) "block")
     (progn
     (while (/= (cdr (assoc 0 SubscriberBlockList)) "block")
       (prompt "\nSelect an object: ")
       );End while function
     );End progn
   );End Function
Message 7 of 27
Sea-Haven
Ok a couple of suggestions
1st
(( is not needed
2nd
);End Function
) ; this is end of defun missing )
Ok so trying  a bit more walking slowly not running.
; an attempt by AlanH Dec 2022
(defun c:wow (/)
; Sort functions By pbejse forums/autodesk
  (defun _n (str / s)
    (setq s (vl-string-right-trim "0123456789" str))
    (list s (atoi (substr str (1+ (strlen s)))))
  (Defun ThisSortFunc (l)
         (Vl-sort l '(lambda (n m)
                             (setq n (_n (Car n)) m (_n (Car m)))
                       (cond
                         ((< (Car n) (car m)))
                         ((eq (Car n) (car m)) (< (Cadr n) (cadr m)))
  (defun c:wow (/)
    (princ "\n Pick 1 block object for block name ")
    (setq ss (ssget "_+.:E:S" '((0 . "INSERT"))))
    (if (= ss nil)
      (alert "You may not have picked a block please try again")
      (progn
        (setq blk (vlax-ename->vla-object (ssname ss 0)))
        (setq bname (vla-get-name blk))
        (if (wcmatch bname "*U#*")
          (setq bname (vla-get-effectivename blk))
        (princ "\nSelect the blocks ")
        (if (= ss nil)
          (progn
            (setq lst '())
              (setq lst2 '())
              (setq blkname (vla-get-name blk))
              (if (wcmatch blkname "*U#*")
                (setq blkname (vla-get-effectivename blk))
              (if (= blkname bname)
                (progn
                  (if (= atts nil)
                    (princ "No Atts")
                    (progn
                      (foreach att atts
                        (setq lst2 (cons (vla-get-textstring att) lst2))
                      (setq lst (cons lst2 lst))
            (setq lst (ThisSortFunc lst))
    (princ)
  (c:wow)
So if you look at lst type !lst you can see we are getting somewhere.
(("368" "") ("369" "") ("370" "") ("371" "") ("372" "") ("403" ""))
Next task is to look for OD data and add to the list.
Message 8 of 27
timothy.birdwell
So when I try to run this code I get a bad ssget mode string error.
Message 9 of 27
paullimapa
What if you changed it to:
"_+.:E:S"
Paul Li
IT Specialist
@The Office
Message 10 of 27
timothy.birdwell
Thanks that fixed, that error. So this code as it stands right now is suppose to only extract information? I can select named object, and now objects, press enter, doesn't show anything, command ends for me.
Message 11 of 27
paullimapa
After running that code did you do as @Sea-Haven instructed:
At command prompt: type !lst
you should get something like:
Paul Li
IT Specialist
@The Office
Message 12 of 27
timothy.birdwell
Ok I was typing generic list, that was straight up user error. Im watching some videos and taking notes, using the code he wrote to write notes next to it with ; so I can see what each area is doing. As the "O.D." I believe I read yesterday that its a sub list with a prefix code of 1000. Going to see if I can get that extracted now.
Message 13 of 27
timothy.birdwell
6 hours in and a little defeated, Im slowly learning and got a few functions to work. This is what I have so far, I just can not find anything that shows how to get OD info.
(DEFUN DXF (i l)(cdr (assoc i l)))
;    SELECT BLOCK, EXTRACT OD     ;
(defun c:foo (/ *ERROR* DAS SOURCE bname TEMPSS)
  ;SELECT BLOCK
  (SETQ DAS (ENTSEL "PLEASE CHOOSE AN OBJECT: "
            )) ;SELECT ENTITY
  (SETQ SOURCE (ENTGET (CAR DAS)));GET ENTITY INFO
  ;MAKE SURE ITS A BLOCK
  ;(= (dxf 0 SOURCE) "INSERT")
  ;GRAB ITS BLOCK NAME
  (setq bname (dxf 2 SOURCE))
  ;GET ALL BLOCKS
  (SETQ TEMPSS
         (SSGET)
  ) ; _SETQ
  ;PROCESS THE BLOCKS
Message 14 of 27
paullimapa
if O.D. you mean extended entity data then take a look at this example:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/extended-entity-data-in-lisp/td-p/69...
Paul Li
IT Specialist
@The Office
Message 15 of 27
Sea-Haven
Change this line did original off the top of my head should have looked it up.
ssget Function Reference | Lee Mac Programming (lee-mac.com)
Message 16 of 27
timothy.birdwell
So I believe I somewhat understand from looking at this, but do not fully comprehend. I can find the string information on the block, but as the OD goes I am unable to find it. I found routine "XDA" from Gilles (gile), tried it and when I selected the object it stated it has no Xdata. I am fully stumped here. *UPDATE* This is working in autocad map3d, a program I've been learning rapidly. The OD I can seperate by exporting as a .shp file and re-importing it. Could this be the reason why I am unable to find the code?
Message 17 of 27
Sea-Haven
Look at this example it should help you.
(setq ent (car (entsel "\n Select object for OD: ")))
(setq Address (ade_odgetfield ent odname "ADDRESS_TYPE" 0))
(setq Pcode (ade_odgetfield ent odname "POSTAL_CODE" 0))
Message 18 of 27
timothy.birdwell
I'm still researching, and finding information. When I try to add the odd code, it overrides the previous. Any good suggestions of videos that can break it down barny style for me?
Message 19 of 27
timothy.birdwell
I'm a little all over the place now. The biggest thing I can't do is find those other values. I'll show you where I am at right now, I know the code is redundant, but I'm trying to figure out what each line does.
(defun c:NestedAttValues (/ Sel Obj)
  (defun _n (str / s)
                       (cond
(defun PrintAttList (BlkObj)
(print
(list
(vla-get-Name Obj)
(mapcar '(lambda (x) (cons (vla-get-TagString x) (vla-get-TextString x)))
(vlax-invoke Obj 'GetAttributes))
(defun GetNestedBlocks (BlkName BlkCol)
 (setq att_lst nil)
 (setq ss (ssget "X" (list (cons 0 "INSERT"))))
  (if ss
   (progn
    (setq C 0)
    (repeat (sslength ss)
     (setq blk (ssname ss C))
     (setq elist (entget blk))
     (setq bn (cdr (assoc 2 elist))); blockname
     (vlax-for Obj (vla-Item BlkCol BlkName)
      (if (= (vla-get-ObjectName Obj) "AcDbBlockReference")
       (progn
        (PrintAttList Obj)
        (GetNestedBlocks (vla-get-name Obj) BlkCol)
);end fun
(setq BlkCol (vla-get-Blocks (vla-get-ActiveDocument
(vlax-get-Acad-Object))))
(if
 (and
  (setq Sel (entsel "\n Select block to get nested attributes: "))
  (setq Obj (vlax-ename->vla-object (car Sel)))
  (progn
   (MakeAttLists Obj)
   (GetNestedBlocks (vla-get-Name Obj) BlkCol)
  ); progn
 );and
 (setq C (+ C 1))
); if
(princ)
(progn
 (PrintAttList Obj)
(princ)
    (if (= ss nil)
      (progn
        (if (= ss nil)
          (progn
            (setq lst '())
              (setq lst2 '())
                (progn
                  (if (= atts nil)
                    (princ "No Atts")
                    (progn
                      (foreach att atts
    (princ)
  ) ;endfun
Message 20 of 27
Sea-Haven
Had another go try this version, pick the 368 block then window the others.
(defun _n (str / s)
                       (cond
(defun c:wow ( / )
(if (= ss nil)
(progn
(if (= ss nil)
(progn
(setq lst '())
(setq lst2 '())
(setq ent (ssname ss (setq x (- x 1))))
(setq blk (vlax-ename->vla-object ent))
(progn
(if (= atts nil)
(princ "No Atts")
(progn
(foreach att atts
(setq odname (ade_odgettables ent))
(setq Stnum (ade_odgetfield ent odname "STREET_NUMBER" 0))
(setq Stname (ade_odgetfield ent odname "STREET_NAME" 0))
(setq state (ade_odgetfield ent odname "STATE" 0))
(setq lst (cons (list  (car lst2) (strcat stnum " " stname " " state " " pcode)) lst))
(setvar 'attreq 0)
(command "-insert" "Fiber_Ped" (getpoint "\nPick insertion point ") 9 9 0)
(setvar 'attreq 1)
(setq len (length lst))
(setq blkatts (vlax-invoke (vlax-ename->vla-object (entlast)) 'Getattributes))
(setq x 0 Y 0)
(repeat (- 12  len)
(vla-put-textstring (nth x blkatts) (strcat (car (nth y lst)) " " (cadr (nth y lst))))
(setq x (1+ x) y (1+ y))
(princ)
(c:wow)
