Lisp for color changing...
rob.aHH2T8
Message 1 of 26
rob.aHH2T8
I need a lisp that turns every layer in a drawing from one color to another.  In my case it's blue to magenta, but I'd like to be able to customize it.  So, if the code is hard to decipher, please point it out.
Thank you!
Replies (25)
Message 2 of 26
ronjonp
Try this:
(defun c:foo (/ old new)
  (setq	old 5
	new 6
  (vlax-for l (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
    (if	(= old (vla-get-color l))
      (vla-put-color l new)
  (princ)
Message 3 of 26
Kent1Cooper
That is clearly "doable," but it's not clear to me exactly what you want to do.  Is it to find all Layers that have blue color assigned to them, and change their color to magenta?  And only those Layers?  That is, does "every layer" in your description refer not to every layer in the drawing, but to every layer with a particular color assigned?
If that's the intent, it can be done pretty simply without any code.  Open the Layer Manager and pick on the Color heading at the top of the color indicator column, to sort the Layers by color.  That will put all those that are blue together, making it easy to select them together and change their color collectively.  But it could certainly be automated, if you really need that.
Kent Cooper, AIA
Message 4 of 26
rob.aHH2T8
Unknown command...
Message 5 of 26
rob.aHH2T8
Yes, only layers that are blue- change to magenta.
Message 6 of 26
ronjonp
@rob.aHH2T8 wrote:
Unknown command...
Message 7 of 26
rob.aHH2T8
Added
(vl-load-com)
to the end of the file... to no avail.
Message 8 of 26
john.uhden
@rob.aHH2T8
Did you save the file and then load it?
Or did you copy the code into your command line?
Or did you enter the command as "C:foo?"  If so, the command is just "FOO."
John F. Uhden
Message 9 of 26
ronjonp
@rob.aHH2T8 wrote:
Added
(vl-load-com)
How are you loading the code ? Perhaps read THIS if you're having problems.
Message 10 of 26
rob.aHH2T8
I've loaded lisps before... (see attachment)
Message 11 of 26
paullimapa
further developing @ronjonp foo code try this:
; foo.lsp function changes every layer in a drawing from a selected color to another selected color
(defun c:foo (/ ccol get_color lyrtbl new old)
  (vl-load-com)
  ; get_color presents color chart & returns color selected from AutoCAD's 255 color index
  (defun get_color (col)
   (acad_colordlg col nil) ; select from AutoCAD 255 color index chart color to change
  (setq	lyrtbl (tblsearch"layer"(getvar"clayer")) ; get current layer
	      ccol (abs(cdr(assoc 62 lyrtbl))) ; get current layer color
  (if (setq old (get_color ccol)) ; get old layer color
    (progn
     (if (setq new (get_color old)) ; get new layer color
       (progn
        (vlax-for l (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))) ; loop through all layers
          (vla-put-color l new) ; change all match colors
        (alert(strcat"All Layers with Color [" (itoa old) "] Successfully changed to Color: [" (itoa new) "]"))
       ) ; progn
       (princ"\nNo Color Selected.")
	   ) ; if new color selected
    ) ; progn
  ) ; if old color selected
  (princ)
) ; defun foo
Paul Li
IT Specialist
@The Office
Message 12 of 26
ronjonp
I'm not sure what's going on. It works as intended on my machine. 🤔
Message 13 of 26
rob.aHH2T8
Does the "princ" part need to be at the end?
Message 14 of 26
rob.aHH2T8
This one didn't work either.
Message 15 of 26
ronjonp
The (princ) is a quiet end and has no impact on how the code runs. What errors are you seeing ? I see that @paullimapa posted some code too but "it does not work' is fairly vague.
Message 16 of 26
rob.aHH2T8
Unknown command.
Message 17 of 26
Sea-Haven
Which is correct, I have
Full Autocad or CIV3D or Architecture
LT
Autocad MAC
Bricscad
Another cad program
Message 18 of 26
paullimapa
the problem is you're not saving the contents of the code into a file that AutoCAD will load automatically.
From your captured image, it shows file name as: acad
But for AutoCAD to load the file automatically, it should be: acad.lsp
And this file needs to be in one of the AutoCAD support search path which is listed under OPTIONS>Files>Support File Search Path
So do this: open attached FOO.zip and then save FOO.lsp into one of the above folders.
Then at the AutoCAD command prompt enter:
(load"foo")
FOO
Paul Li
IT Specialist
@The Office
Message 19 of 26
ronjonp
@rob.aHH2T8 wrote:
Unknown command.
Try to copy and paste the code into the command line then call 'FOO'. You're missing a step somewhere me thinks.
Message 20 of 26
rob.aHH2T8
The lisp above it works...
