Message 1 of 9
AutoCAD Experts,
I am trying to implement a LISP routine where the layers from an external consultants DWG file are automatically changed to reflect my layer conventions. I've found an easy LISP routine (attached) which uses the laymrg function, however the issue is when the layer does not exist in the DWG (which is common as consultants often purge their DWG's before releasing) the LISP will not function properly. Any advice on how to overcome this issue? Any help would be greatly appreciated.
