LISP for automatic layer changing
liamQ8LGU
Message 1 of 9
liamQ8LGU
AutoCAD Experts,
I am trying to implement a LISP routine where the layers from an external consultants DWG file are automatically changed to reflect my layer conventions. I've found an easy LISP routine (attached) which uses the laymrg function, however the issue is when the layer does not exist in the DWG (which is common as consultants often purge their DWG's before releasing) the LISP will not function properly. Any advice on how to overcome this issue? Any help would be greatly appreciated.
Replies (8)
Message 2 of 9
Sea-Haven
To stop layer is missing problems just add does layer exist 1st, (tblsearch "LAYER" layername) will return T if layer exists.
Message 3 of 9
liamQ8LGU
Thank you, I think this is the solution but I am a LISP routine noob and not sure exactly how to implement. Are you able to attach the original LISP I included with the tblsearch as required?
Message 4 of 9
Sea-Haven
Need a rewrite
(setq laylst (list (list "RIDGER" "Ex_Building Roof")
(list "DTM_Existing_contours" "Ex_Contours")
(list "PAVER" "Ex_Pavers")
(list "RIDGE" "Ex_Building Roof")))
(foreach lay laylst
(if (tblsearch "layer" (cadr lay))
(Command "_laymrg" "t" (car lay) "" "t" (cadr lay) "y")
Not tested.
Message 5 of 9
liamQ8LGU
Unfortunately I'm not having any luck with merging the two LISP's. I'm still getting the same problem when a layer doesn't exist.
Message 6 of 9
ВeekeeCZ
Maybe use a feature that is already built in? SEE HERE
Message 7 of 9
Kent1Cooper
Shouldn't it test for the presence of both Layers for each merge?  How about [untested]:
(defun C:LC (/ pairs)
  (setq pairs
      ("RIDGER" "Ex_Building Roof")
      ("DTM_Existing_contours" "Ex_Contours")
      ("PAVER" "Ex_Pavers")
      ("RIDGE" "Ex_Building Roof")
    ); list
  ); setq
  (foreach pair pairs
    (if (and (tblsearch "layer" (car pair)) (tblsearch "layer" (cadr pair)))
    (command "_.laymrg" "_t" (car pair) "" "_t" (cadr pair) "y")
  ); foreach
  (prin1)
); defun
Kent Cooper, AIA
Message 8 of 9
liamQ8LGU
Perfect! Thanks so much. Any idea if there is a similar option for blocks??
Message 9 of 9
Sea-Haven
Pretty obvious
(tblsearch "BLOCK" "Northn")
((0 . "BLOCK") (2 . "NORTHN") (70 . 0) (10 0.0 0.0 0.0) (-2 . <Entity name: 3d3ef360>))
