Lisp for Area
Lisp for Area
shijomon_josephBCZCE
Message 1 of 25
Lisp for Area
I am seeking a Lisp to assist with area calculations. The intended functionality is to allow selection of dimensions from a polyline, or a poly line itself after which the routine should automatically compute and add either the length or width. This tool is intended for use in wall elements represented in plan view, where the height is already known. The calculated area needs to be annotated on each wall throughout a large building project.
Please hel me to find a solution for it.
Replies (24)
Message 21 of 25
Hi , Thankyou for your support.
Message 22 of 25
Dear Moshe,
Apologies for disturbing you again.
The Lisp result is showing all values as 0.000 m². Please see the attached screenshot for reference.
Could you kindly assist in resolving this issue?
Message 23 of 25
Moshe-A
@shijomon_josephBCZCE ,
did you set elevation instead of thickness?
Message 24 of 25
Yes, elevation only. Please refer to the property details shown in the image..
Message 25 of 25
Moshe-A
You need to set thickness (not elevation)
if you set elevation the all lines will 'jump' into  air and you do not want that
