Lisp for Area
Lisp for Area
shijomon_josephBCZCE
Message 1 of 25
Lisp for Area
I am seeking a Lisp to assist with area calculations. The intended functionality is to allow selection of dimensions from a polyline, or a poly line itself after which the routine should automatically compute and add either the length or width. This tool is intended for use in wall elements represented in plan view, where the height is already known. The calculated area needs to be annotated on each wall throughout a large building project.
Please hel me to find a solution for it.
Replies (24)
Message 2 of 25
Moshe-A
@shijomon_josephBCZCE  hi,
As you know, AutoCAD (in vanila version) does not knows what walls is 😀 it does knows AutoCAD objects like lines, arcs, plines. so to have an area calculation (post a sample dwg so we can understand how you are doing it manually) you need to draw close plines in each room. only then a lisp program can produce some area calculations.
Moshe
Message 3 of 25
Hi Moshe,
Thanks for your response.
The issue I'm facing is that the wall is shown in its actual location, but I need to calculate the area of the wall based on its height, which is determined by the level. This makes it difficult to use traditional rectangular area calculations.
For example, if a wall is 10 meters in length and 7.5 meters in height, the width is not defined (L = 10, W = ?, H = 7.5), and this information is not available directly from the plan view. Therefore, I’m unable to pick the area using standard methods.
I’m looking for a Lisp program that can help me calculate the wall area by selecting a polyline and entering the height during selection. The program should then annotate the calculated area directly at the wall’s location along with the dimensions.
Let me know if you have any suggestions or if such a tool is available.
Message 4 of 25
Moshe-A
if you want to input the length, width, height for each pline then an old manual calculator will do the same job as lisp
Message 5 of 25
Hi
please find the picture of the wall and the length in 2D plan marked with dimensions. And the height of the wall is 7.7m. So, i need to manually calculate the area to annotate each one of them.
Example = 9.78 m length of a wall with the height of 7.7m = 75.306m²
Message 6 of 25
Moshe-A
So you want a lisp the let you select a dimension (or a wall face) ask you the height than write down the area
the height of all walls is not the same?
why can't you post a sample dwg?
Message 7 of 25
autoid374ceb4990
Your second picture is quite different from the first.   Please post the DWG files.
Message 8 of 25
Moshe-A
Here is my suggestion to think of 😀
create a layer (say call it "geo_layer") draw\trace using pline wall faces. set each pline with elevation (as wall height) use properties palette
warp the following program in calarea.lsp file than load it in your drawing.
run the lisp: CALAREA and select all plines (only on geo_layer) 'boom' you will get all areas.
you can control a few properties in code (starting from line# 32)
; define some constants
(setq GEOLAYER "geo_area") ;  the layer the plines will be found , set it any color you like
(SETQ TARLAYER "text_area") ; the layer text (cal area) will be laid , set it any color you like
(SETQ TEXTSIZE 0.3) ; text height in meters
(setq TEXTOFSET 3)  ; text offset factor
the program use the current text style, so make sure you set the right one.
enjoy
Moshe
;;; calarea.lsp
;;; by Moshe-A
;;; SEP 2025
(vl-load-com) ; load activex support
(defun c:calarea (/ cal_text_pos readable_text ; local functions
		    GEOLAYER TARLAYER TEXTSIZE TEXTOFSET
		    adoc layers modelSpace ss ename AcDbPLine plen hgt mpx mp0 mp1 p0 p1 p2 AcDbText)
 (defun cal_text_pos (t0 t1 t2)
  (polar t2 (+ (angle t0 t1) (* pi 0.5)) (* 0.3 3))
 ); cal_text_pos
 (defun readable_text (t0 t1 / a0)
  (setq a0 (angle t0 t1))
  (if (and (> a0 (* pi 0.5)) (< a0 (* pi 1.5)))
   (+ a0 pi)
   a0
  ); if
 ); readable_text
 ; here start c:calarea
 (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
 (vla-startUndomark adoc)
 (setq layers (vla-get-layers adoc))
 (setq modelSpace (vla-get-modelspace adoc))
 (setq GEOLAYER "geo_area") 	; const
 (SETQ TARLAYER "text_area")	; const
 (SETQ TEXTSIZE 0.3)		; const
 (setq TEXTOFSET 3)		; const
 (if (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list layers TARLAYER))))
  nil
  (vla-add layers TARLAYER)
 (if (setq ss (ssget (list '(0 . "lwpolyline") (cons '8 GEOLAYER))))
  (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
   (setq AcDbPLine (vlax-ename->vla-object ename))
   (setq plen (vla-get-length AcDbPLine))	; pline length
   (setq hgt (vla-get-elevation AcDbPLine))	; elevation
   (setq mpx (* (vlax-curve-getEndParam ename) 0.5)) ; middle param
   (setq mp0 (fix mpx))
   (setq mp1 (1+ (fix mpx)))
   (setq p0 (vlax-curve-getPointAtparam ename mp0))
   (setq p1 (vlax-curve-getPointAtParam ename mp1))
   (setq p2 (vlax-curve-getPointAtParam ename mpx))
   (setq AcDbText (vla-addText modelSpace (strcat (rtos (* plen hgt)) "m" (chr 178)) (vlax-3d-point p2) 0.3))
   (vla-put-rotation AcDbText (readable_text p0 p1))
   (vla-put-alignment AcDbText acAlignmentMiddle)
   (vla-put-textAlignmentPoint AcDbText (vlax-3d-point (cal_text_pos p0 p1 p2)))
   (vla-put-layer AcDbText TARLAYER)
   (vlax-release-object AcDbText)
   (vlax-release-object AcDbPLine)
  ); foreach
 ); if
 (vlax-release-object modelSpace)
 (vlax-release-object layers)
 (vla-endUndoMark adoc)
 (vlax-release-object adoc)
 (princ)
); c:calarea
Message 9 of 25
Sea-Haven
My $0.05 you can set a wall "THICKNESS" this is the wall height so picking a line and just multiply by the thickness, you could select lots of lines and set Thickness. Use Properties. In this image the wall height has been set but is viewed in a 3d view. Just type thickness set a value then draw a line, then vpoint -1,-1,1 you will see the thickness. You wont see Thickness in PLAN view.
Message 10 of 25
Moshe-A
@shijomon_josephBCZCE ,
Opps i thought about thickness but used elevation - sorry my bad 😂 that's what happen when you do it late at night.
so @Sea-Haven you go it right.
Attach is the corrected version.
Moshe
Message 11 of 25
Hi Moshe
Thankyou very much for your support.
Unfortunately, the lisp notworking as you explained. see the image attached here for more clarity.
Once the command is activated then it prompts to select objects...  But when i select the poly line it says "0" found
Message 12 of 25
Hi ,
Thankyou for your reply. unfortunately, this method is not suitable for me. i need all pure in 2D drawing
Message 13 of 25
Please find here a sample drawing attached.
I need the area annotated in each dimension with uniform wall height 7.7m
Message 14 of 25
Dwg file attached
Message 15 of 25
Moshe-A
change "geo_layer" to "geo_area"
; next line comes from calarea.lsp
prepare your drawing by tracing your wall for calarea on "geo_area" layer than select all these plines and set them 7.7m thickness
now it will work 😀
Message 16 of 25
Dear Moshe
I am very thankful to you.  Its worked well as i expected and saved my life to easy...
Thank you very much...
Message 17 of 25
Moshe-A
Ahhh 😆 that was quick, glade i could help
study the properties you can set and use them.
with :
You can control the offset of the text from face of the wall.
if you make changes to your walls do not forget to stretch the "text_area" plines also and run the command again.
cheers
Moshe
Message 18 of 25
Sure... 🙏
Message 19 of 25
komondormrex
somewhat same with fields
(defun c:add_area (/ dim_sset)
  (foreach dim (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex (setq dim_sset (ssget '((0 . "dimension"))))))))
    (vla-put-textoverride dim (strcat "<>\\P%<\\AcObjProp.16.2 Object(%<\\_ObjId "
                      (itoa (vla-get-objectid dim))
                      ">%).Measurement \\f \"%lu2%ct8[7.7]\">% m\\U+00B2"
  (command "_updatefield" dim_sset "")
  (princ)
Message 20 of 25
Sea-Haven
"I need all pure in 2D drawing" thickness is like a quasi 3d aspect, you will not see it in any 2d dwg the only time you will see it is if you view in 3d. So still suggest use thickness, you can set various parts of your dwg with different "thickness" so will work out area matching that wall height. I would suggest you just give it a try.
This is your dwg with 2 different wall heights. You can only see it in a 3d view. For all intents and purposes its 2D.
