LISp for area and length
Steve_-B
Message 1 of 8
Steve_-B
First post so please go easy if I'm posting in wrong forum.
Basically, I'm trying to find a way to write a script to state the length against all open polyines and state the area inside all closed polylines in one macro.  I've found a macro for each task but have no idea how to combine them.  I also need the length/area tex to be on the same layer as the line they reference.
Something like the below as I need to take of lots of information from plans and constantly clicking a line and then looking at the properties and copying to Excel is very time consuming.
Any assistance would be much appreciated.  Thanks.
Replies (7)
Message 2 of 8
Kent1Cooper
@Steve_-B wrote:
....  I've found a macro for each task but have no idea how to combine them.  ....
Post them.  Someone could much more easily show you how to combine them than come up with an approach from scratch [or find things to combine in this Forum].
Kent Cooper, AIA
Message 3 of 8
ВeekeeCZ
Try this one.
(vl-load-com)
(defun c:PLenarea  (/ spc doc s i l e o vrs pts oid pnt fld txt)
  (setq spc (vla-get-modelspace (setq doc (vla-get-activedocument (vlax-get-acad-object)))))
  (vla-startundomark doc)
  (if (setq s (ssget '((0 . "CIRCLE,LWPOLYLINE,LINE,ARC"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
	    o (vlax-ename->vla-object e)
	    l (cdr (assoc 8 (entget e))))
      (if (or (= "CIRCLE" (cdr (assoc 0 (entget e))))
	      (and (= "LWPOLYLINE" (cdr (assoc 0 (entget e))))
		   (= 1 (getpropertyvalue e "Closed"))))
	(setq vrs (cond ((cdr (assoc 90 (entget e)))) (1))
	      pts (apply 'mapcar (cons '+ (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget e)))))
	      pnt (mapcar '/ pts (list vrs vrs))
	      oid (itoa (vla-get-objectid o))
	      fld (strcat "%<\\AcObjProp Object(%<\\_ObjId " oid ">%).Area \\f \"%lu2%ps[, m2]%ct8[1.0E-006]\">%"))
	(setq pnt (vlax-curve-getpointatdist e (/ (vlax-curve-getdistatparam e (vlax-curve-getendparam e)) 2))
	      fld (strcat "%<\\AcObjProp Object(%<\\_ObjId " oid ">%).Length \\f \"%lu2%ps[, m]%ct8[1.0E-003]\">%")))
      (setq txt (vla-addMText spc (setq pnt (vlax-3d-point pnt)) 0 fld))
      (vla-put-layer txt l)
      (vla-put-AttachmentPoint txt acAttachmentPointMiddleCenter)
      (vla-put-InsertionPoint txt pnt)
  (vla-endundomark doc)
  (princ)
Message 4 of 8
Steve_-B
Wow, that is really good and just what I need.  I appreciate your help and don't want to abuse it but is there a way to get the text to adopt the layer of the line it's referencing?
I also need to change the units (my drawings are in mm and mm2 but I want the text to be m2 as you've put in your code), also decimal points and rounding up to the nearest single decimal point.  However I want to try and work this out myself as don't want to take liberties.
thanks again
Message 5 of 8
ВeekeeCZ
Ok, code updated.
Message 6 of 8
Steve_-B
thank you so much
Message 7 of 8
calderg1000
Regards @Steve_-B
Here I show you my simple proposal, using only Vanilla autolisp.
For open polylines it calculates only length, for closed polylines it calculates length and area.
Important note: Works with any text style similar to Standard (height=0)
(defun c:apl (/ s a p h pt l)
  (setq s (entsel "\nSelect Lwpolyline: "))
  (command "_area" "_o" (car s))
  (setq a  (getvar 'area)
        p  (getvar 'perimeter)
        h  (getreal "\nEnter Height Text: ")
        pt (cadr s)
        l  (cdr (assoc 8 (entget (car s))))
        tl (strcat "\nL= " (rtos (* p 1e+3) 2 2) " mm")
        ta (strcat "\nL= " (rtos (* p 1e+3) 2 2) " mm" "; " "A= " (rtos a 2 2) " m2")
  (if (= (cdr (assoc 70 (entget (car s)))) 128)
    (command "_text" "_near" pt h 0.0 tl)
    (command "_text" "_near" pt h 0.0 ta)
  (command "_chprop" (entlast) "" "la" l "")
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 8 of 8
Steve_-B
thank you
