LISP : Find Distance of multiple parallel lines from a single baseline
jaggisingh003
Message 1 of 15
jaggisingh003
Hi All,
I have a requirement of finding the distance of multiple parallel lines from a single baseline.
I want LISP that will allow me to select the baseline(from which I need the distance of other lines) and lines for which I need distance. Here in the image below, the yellow line is the baseline and I need distance for all other lines from the yellow line.
If anyone has worked on this before, kindly help me out.
Replies (14)
Message 2 of 15
Kent1Cooper
@jaggisingh003 wrote:
…. I have a requirement of finding the distance of multiple parallel lines from a single baseline.
I want LISP that will allow me to select the baseline(from which I need the distance of other lines) and lines for which I need distance. ….
That's not difficult, but in what form do you want the distances?  Reported at the Command line?  Written as Text in the drawing?  Sent out to a text or spreadsheet file?  Something else?
Kent Cooper, AIA
Message 3 of 15
Moshe-A
if i send you a program that will print a list of the distances between the lines. can you take it from there and complete what you want to do?
Moshe
Message 4 of 15
jaggisingh003
In in AutoCAD text  format....
Message 5 of 15
jaggisingh003
Thanks. Moshe
 I am happy to use your code. but I don't have any knowledge of Lisp programming.
Message 6 of 15
Moshe-A
then you did not explained what would you do with the list of distances? it's only a list of numbers?
you want only to know the distances or you want to do something with it?
Message 7 of 15
Kent1Cooper
You can use ORDINATE DIMENSIONS.  Make a Dimension Style with both extension lines suppressed if you want only the textual part.  Specify the Xdatum option.  If your reference line isn't at X=0, you can put them all in with the "wrong" values, and afterwards select them all, and STRETCH the shared grip at 0,0 to anywhere on that Line.
Kent Cooper, AIA
Message 8 of 15
jaggisingh003
see this image.....
I have to write the distance from baseline at the specified place. like this image..
Message 9 of 15
jaggisingh003
I don't use ordinate dimensions. I am using baseline dimension for this like the image below...
baseline dimensionsbaseline dimensions Remove extension lines in dimension style.
Message 10 of 15
Moshe-A
so what you want to do is to specify an horizontal line and the lisp will draw all the base dimension from your specified base line?  are you using a special dimension style? post the dwg
Message 11 of 15
jaggisingh003
Yes, you get it correct.
No, I am not using any special type dimension style only.
please find the attached drawing for more information.
Message 12 of 15
Moshe-A
are you sure you are doing dimbaseline? cause what i see in your file is just horizontal dimensions between the lines and for that kind of dimension you do not need any lisp use the QDIM command it will do just prefact what you want.
Message 13 of 15
jaggisingh003
see this
Message 14 of 15
Moshe-A
Ok i see now what you mean.
here is AutoDB command to do what you want
first you be asked to specify the 1st dimension line point: you need to pick the 1st point to the left of your base line. than pick the 2nd point to the right (turn ortho on) over the last line
the lisp will select all lines (only lines and if there are other lines remove them) by "Fence"
than the dimensions will be drawn
improve your dimension style so the outcome will be more readable.
if this suits you, mark it as solusion.
enjoy
moshe
(defun c:AutoDB (/ p0 p1 ss lst^ p13 item0 item1)
 (setvar "cmdecho" 0)
 (command ".undo" "_begin")
 (if (and
       (setq p0 (getpoint "\nSpecify first dimension line point: "))
       (setq p1 (getpoint p0 "\nSpecify second dimension line point: "))
       (setq ss (ssget "F" (list p0 p1) '((0 . "line"))))
  (progn
   (setq lst^ (vl-sort (ssnamex ss) (function (lambda (item0 item1) (< (distance p0 (cadr (last item0))) (distance p0 (cadr (last item1))))))))
   (setq item0 (car lst^) item1 (cadr lst^))
   (command "._dimlinear" (setq p13 (cadr (last item0))) (cadr (last item1)) (polar p13 (/ pi 2) (* (getvar "dimtxt") (getvar "dimscale")))
            "._dimtedit" "_last" "_right")
   (foreach item1 (cddr lst^)
    (command "._dimbaseline" (cadr (last item1)) "" ""
             ".dimtedit" "_last" "_right")
   ); foreach
  ); progn
 ); if
 (command "._undo" "_end")
 (setvar "cmdecho" 1)
 (princ)
Message 15 of 15
jaggisingh003
It is highly appreciable for the code provided by you.
Thanks for the kind & quick reply.
Thanks  a lot, Moshe
