LISP FAILURE
LISP FAILURE
LISP FAILURE
Hello good people.
can anyone help with the two LISP routines I have attached?!
Until a few weeks these routines run fine but for no reason now fail and we don't know why.
Any help would be greatly appreciated.
Cheers
ВeekeeCZ
Would you post some test file?
Would you describe what this should do and does not?
btw. you should turn the osnaps off when you're inserting a block:
(command "-insert" "PITNO-CAPSULE" "_none" point 1 1 0 pitno lineno)
(command "-insert" "CATCHMENTARROW" "_none" myPos1 1 1 0 myArea myTag)
And check ATTREQ variable.
Thank you for your quick response.
I have attached a drawing showing what is required from the LISP routines.
They are pretty easy to follow but if you need any further information please don't hesitate to ask.
Thanks in advance.
ВeekeeCZ
Ok, then you don't hesitate to try my suggestions. Cheers!
