- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
hi I have a great lisp to draw a cut off pipe end, that works in ACAD 2013-2015.....I get this error in 2017 : "Error: bad argument type: 2D/3D point: nil"....
(see attached)
..I see most people post the whole lisp here , so...
(defun c:pipe (/ plwid first second pt1 pt2 ang dis pt3 layr entl)
(setq olderr *error* *error* pipe_err)
(setq plwid (getvar"plinewid"))
(setvar"plinewid" 0)
(while (not
(setq first (entsel "\nPick first endpoint: ")))
(prompt "\nNo endpoint found. ")
(while (not
(setq second (entsel "\nPick second endpoint: ")))
(if second
(progn
(setq pt1 (osnap (cadr first) "qui,end")
pt2 (osnap (cadr second) "qui,end")
(setq ang (angle pt1 pt2)
dis (distance pt1 pt2)
pt3 (polar pt1 ang (/ dis 2.0))
(command "pline" pt1 "arc" "a" "100" pt3 pt2 "a" "-100" pt3 ""))
(setq layr (cdr (assoc 8 (entget (car first))))
entl (entget (entlast))
(setq entl (subst (cons 8 layr)(assoc 8 entl) entl))
(entmod entl)
(setvar "plinewid" plwid)
(setq *error* olderr)
(princ)
(defun pipe_err (s)
(if (/= s "Function cancelled")
(princ (strcat "\nError: "s))
(setvar"plinewid" plwid)
(if olderr (setq *error* olderr))
(princ)
anybody have a few minutes to have a look?..
thanks
