Lisp error rejected
Lisp error rejected
kidznok
Message 1 of 17
Lisp error rejected
kidznok
Hi
I try with lisp to reset scale list when someone will save file.
I found sth like this
(defun AtSaveCommand (calling-reactor b)
(if
(or
(= (car b) "QSAVE")
(= (car b) "SAVEAS")
(= (car b) "SAVE")
(command "-SCALELISTEDIT" "R" "Y" "E")
(defun loadTheSaveReactor ()
(vl-load-com)
(if *FileOnSave* (vlr-remove *FileOnSave*))
(setq *FileOnSave*
(vlr-command-reactor nil '((:vlr-commandwillStart . AtSaveCommand)))
(loadTheSaveReactor)
And i have "error no function definition:scalelistedit"
Could someone help me?
Replies (16)
Message 2 of 17
hak_vz
Replace command function with vl-cmdf and it should work.
(if
(or
(= (car b) "QSAVE")
(= (car b) "SAVE")
(vl-cmdf  "-SCALELISTEDIT" "R" "Y" "E")
(vl-load-com)
(setq *FileOnSave*
Miljenko Hatlak
Message 3 of 17
kidznok
Thank you.
Error is gone.
But... when I use qsave or save reset scale is not working.
File is save but I have the same scale list.
When I use save I would like to reset scale and then save my file.
Message 4 of 17
Moshe-A
@kidznok  hi,
this will not work cause as far as i know, you can not call (command) function from callback [and that's includes (vl-cmdf) ]
the way to approach this is access the scalelist dictionary data and delete the unwanted scales.
(dictsearch (nameobjdict) "ACAD_SCALELIST")
then dig-in
note that you can not delete scales that are used (the same as layers, linetypes, textstyles)
Moshe
Message 5 of 17
kidznok
Like this?
(if
(or
(= (car b) "_QSAVE")
(= (car b) "_SAVE")
(vl-load-com)
(setq *FileOnSave*
Cause it's not working. Sorry, I'm not good in autolisp.
Message 6 of 17
ronjonp
@kidznok
FWIW
;; This
(defun atsavecommand (calling-reactor b)
  (if (or (= (car b) "QSAVE") (= (car b) "SAVEAS") (= (car b) "SAVE"))
;; Could be shortened to this
  (if (wcmatch (car b) "QSAVE,SAVEAS,SAVE")
;; Or this
  (if (wcmatch (car b) "*SAVE*")
Message 7 of 17
kidznok
I try and unfortunately it not work at my dwg 😕
But thank you.
Message 8 of 17
Moshe-A
@kidznok ,
give this a go 🤣
This is auto delete scales according "measurement" sysvar. if it's 0 - imperial, all metric scale is vanish
if it's 1 - metric, all imperial scale is vanish.
enjoy
Moshe
(vl-load-com)
(defun AtSaveCommand (calling-reactor cmd^ /  ResetScaleList ;| local function |;)
 (defun ResetScaleList (measurement / AcDbScale elist)
  (vlax-for AcDbScale (vla-item (vla-get-dictionaries (vla-get-activedocument (vlax-get-acad-object))) "ACAD_SCALELIST")
   (setq elist (entget (vlax-vla-object->ename AcDbScale)))
   (cond
    ((= measurement 0) ; imperial
     (if (member (cdr (assoc '300 elist)) rdata^)
      (vl-catch-all-apply 'vla-delete (list AcDbScale))
    ); case
    ((= measurement 1); metric
     (if (not (member (cdr (assoc '300 elist)) rdata^))
    ); case
   ); cond
   (vlax-release-object AcDbScale)
  ); vlax-for
 ); resetScaleList
 (if (wcmatch (car cmd^) "QSAVE,SAVEAS,SAVE")
  (ResetScaleList (getvar "measurement")) ; 0 - imperial, 1 - metric
); AtSaveCommand
 (setq rdata^ '("1:1" "1:2" "1:4" "1:5" "1:8" "1:10" "1:16" "1:20" "1:30" "1:40" "1:50" "1:100" "2:1" "4:1" "8:1" "10:1" "100:1"))  ; metric scales
 (if (not *FileOnSave*)
  (setq *FileOnSave* (vlr-command-reactor nil '((:vlr-commandwillStart . AtSaveCommand))))
Message 9 of 17
Sea-Haven
A possible alternative is the 2 VLR functions, rather than check every command, :vlr-commandwillStart
:VLR-beginSave
:VLR-beginClose
Message 10 of 17
Moshe-A
@kidznok ,
a shorter version, use this one 🤣
Moshe
(vl-load-com)
(defun AtSaveCommand (calling-reactor cmd^ / AcDbScale elist)
   (cond
    ((= (getvar "measurement") 0) ; imperial
     (if (member (cdr (assoc '300 elist)) (vlr-data calling-reactor))
    ); case
    ((= (getvar "measurement") 1); metric
     (if (not (member (cdr (assoc '300 elist)) (vlr-data calling-reactor)))
    ); case
   ); cond
  ); vlax-for
 ); if
); AtSaveCommand
		       '("1:1" "1:2" "1:4" "1:5" "1:8" "1:10" "1:16" "1:20" "1:30" "1:40" "1:50" "1:100" "2:1" "4:1" "8:1" "10:1" "100:1") ; vlr-data, metric scales
  ); setq
 ); if
); loadTheSaveReactor
Message 11 of 17
Moshe-A
@kidznok hi,
does it work?
Message 12 of 17
kidznok
No, unfortunately no.
I created aitostart lisp to reset scale so when I open file it's running.
It's a second way for me.
Message 13 of 17
Moshe-A
i use r2022 and it works perfect for me and i am sure you are missing something.
Message 14 of 17
Moshe-A
maybe post your dwg and specify the scalelist names you want to delete
Message 15 of 17
kidznok
Hi, i would like to reset scale, just delete scales from xrefs in BricsCad.
Message 16 of 17
kidznok
It works when I use ctrl+S but not when I use button.
Save as not work too. Is it chance to add reset scale to _close?
I will click X button then it reset scale, next close and ask to save.
I'm just wondering.
Message 17 of 17
Moshe-A
@kidznok  hi,
(if
(or
(= (car b) "QSAVE")
(= (car b) "SAVE")
When you run this code to monitor these commands you can not expect AutoCAD to monitor other commands.
picking the X buttom should invokes the close command but on my experience long time ago it won't 😂
instead vlr-command-reactor you should move to:
vlr-dwg-reactor \ vlr-editor-reactor
using these events
vlr-beginClose \ vlr-beginSave  (as @Sea-Haven  recommended)
Moshe
