Give me a bundle of Lisp File So that I can Run on My Auto CAD Web Application
Rahul_Banerjee
Rahul_Banerjee
From Today's Morning I was Just tired to Load Arc Text Lisp and DCL into my Autocad Web. So I want a bundle of Lisp and DCL file so that I can work easily
paullimapa
Perhaps you can clarify what you mean by bundle
Paul Li
IT Specialist
@The Office
Sea-Haven
Like attached some free, some pay. Still updating got to "C's"
paullimapa
If you're saying you want to select a number of lisp files you have saved in your hard drive for AutoCAD to load automatically everytime the program starts then use the APPLOAD command and look for the Startup Suite Contents button.
Click on this button and on the Startup Suite window click on Add and select as many lisp files you want to have AutoCAD load automatically at startup.
Paul Li
IT Specialist
@The Office
_gile
You can easily build your own .bundle.
See these topics:
About Installing and Uninstalling Plug-In Applications
PackageContents.xml Format Reference
Example: Basic .bundle Folder Structure for a Plug-in
Gilles Chanteau
GileCAD
GitHub
Rahul_Banerjee
Bundle means use many lisp file in one place.
Note - I have used Auto CAD Web Eduction
paullimapa
Since you're using the web version, there's a number of limitations and only one method to load them.
Read up on it here:
AutoCAD web application Help | LISP files | Autodesk
Paul Li
IT Specialist
@The Office
